Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Thread: Hit bump
  1. #11
    Raw Wave
    Jun 2004
    On the beach
    It will need ram to POST from past experience.
  2. #12
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    have you tried it with a normal computer power supply? and if your handy with a mulimeter I believe there is a fuse near the power connector on the motherboard, you might check that as well.
    肚子笑痛了
    S60 Install
  3. #13
    Oct 2004
    im not handy with a multimeter.
    the Opus seems to work fine. It lights on as if it is running. I would hate to buy another motherboard and find that its not my problem.
  4. #14
    Raw Wave
    Jun 2004
    On the beach
    As JCDillin says, try with a normal PC Power Supply in case the OPUS is stuck in its cycle.
  5. #15
    Jul 2004
    Just disconnect the opus from the battery for 5 seconds.
  6. #16
    Oct 2004
    good idea. i should try that also.
    anyway it could be a dead battery on the mobo?
  7. #17
    Jul 2004
    Highly doubt it. Mine sometimes won't power on too, i just have to pop the hood and remove the fuse.
  8. #18
    Oct 2004
    i haven't checked the power fuse but the OPUS powers fine so i doubt the fuse is blown.
  9. #19
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Removing the fuse in the Opus is what he means by resetting it. Seems to be common with Opus P/S's.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
  10. #20
    Oct 2004
    i had no idea there was a fuse in the opus.
    So i open the opus up and remove the fuse then put it back in?
    thanks guys
  1. Lilliput can't survive a bump anymore!!!
    By Rover_Eli in forum LCD/Display
    Last Post: 01-29-2005, 08:54 PM
  2. Computer Crashes When I hit a bump
    By antimatter in forum General Hardware Discussion
    Last Post: 12-15-2004, 11:33 AM
  3. message hit counter
    By edie209 in forum General MP3Car Discussion
    Last Post: 04-18-2001, 01:44 PM
  4. bump = reboot problem SOLVED
    By acitrano in forum General Hardware Discussion
    Last Post: 04-17-2001, 09:37 AM
  5. wondering if ur dvd,cdrom, hd skip when you drive and hit a bump??
    By BobyYoo in forum General MP3Car Discussion
    Last Post: 11-29-2000, 01:41 PM
