Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
Thread: Hit bump
  1. #21
    Oct 2004
    i think he meant the fuse near the battery. He said "pop my hood and remove the fuse."
  2. #22
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    If it isn't internal then yeah, it should be on the main power lead from the battery.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
  3. #23
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    He meant to reset the opus he pulls the main fuse under the hood.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  4. #24
    Oct 2004
    ok, i get it. sorry
    thanks again guys and ill keep you updated.
  5. #25
    Jul 2004
    Did that work for you?
  6. #26
    Oct 2004
    no, it didn't work. =(
    what i don't understand is, how does my usb hub light up? also, when i plug in the PCI wireless card, it also lites up. Still no action from the mobo.
  7. #27
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I know the opus seems like it's still powering on, but did you try it with a normal PC power supply. And have you taken the motherboard off of the mount you made? and then try powering it up?
    肚子笑痛了
    S60 Install
  8. #28
    Oct 2004
    i took it off the mount and still no activity. I haven't tried powering it with a normal power supply yet. Thats what im going to try today. Thanks jcdillin.
  9. #29
    May 2003
    Miami, FL
    After trying that and if it still doesnt work, I would say the motherboard has been toasted.
    肚子笑痛了
    S60 Install
  10. #30
    Oct 2004
    yea, if a normal psu doens't power it up then i guess im screwed.
    Is there anywhere i can see the correct way to mount a motherboard? I would hate to have this happen again. I mounted the board like i would with any computer.
  1. Lilliput can't survive a bump anymore!!!
    By Rover_Eli in forum LCD/Display
    Last Post: 01-29-2005, 09:54 PM
  2. Computer Crashes When I hit a bump
    By antimatter in forum General Hardware Discussion
    Last Post: 12-15-2004, 12:33 PM
  3. message hit counter
    By edie209 in forum General MP3Car Discussion
    Last Post: 04-18-2001, 02:44 PM
  4. bump = reboot problem SOLVED
    By acitrano in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:37 AM
  5. wondering if ur dvd,cdrom, hd skip when you drive and hit a bump??
    By BobyYoo in forum General MP3Car Discussion
    Last Post: 11-29-2000, 02:41 PM
