Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: Hit bump
  1. #31
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Just make sure no other parts then then 2mm around the four holes in the MB touch anything metal.
    This means you should use standoffs, and not screw your board right to a metal plate. If you are a very lucky bastard, that could work for some time, until you hit a bump in the road or something... ;-)
  2. #32
    Oct 2004
    I drill tapped 4 standoff screws into a metal board. Then i layed the mobo on top and screwed 4 screws into the standoff screws. There is about 3-4mm clearance from the metal board to the mobo. Nothing is touching besides the screws on the board. I used the small screws so that the head of the screw is touching nothing besides the area it is supposed to sit on.
    Am i doing anything wrong? I feel so afraid to get a new board then to have it fry again.
  3. #33
    Oct 2004
    would it be better to use plexi glass instead of the metal board?
  4. #34
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    definitely. anything non-conductive will work fine. i was actually gonna suggest a thin sheet of foam runner, but plexi will do just fine.
    Your everyday carpc geek and tech guru at your service. *bow*
  5. #35
    Oct 2004
    <======== learning the hard way
  6. #36
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    3 mm isnt very much. The board could easily flex that much. Mine is about 10 mm off from the case.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  7. #37
    Oct 2004
    damn, i should've known better.
  8. #38
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    It is quite likely the board flexed due to the inertia of the CPU heatsink. this could have also damaged the board due to flexing as well as the possibility of touching the case. You might want to siply use MDF under your board and if possible support the middle to reduce the flexing.
    have you tried re-seating the CPU at all?
  9. #39
    Oct 2004
    yes, i have tried re-seating the CPU. still dead.
    What is MDF and where can i get some of that?
  10. #40
    Oct 2004
    nevermind, MDF = Medium Density Fiberboard
    Can i just use regular wood board? Is there no chance of fire with wood on the bottom of a mobo?
  1. Lilliput can't survive a bump anymore!!!
    By Rover_Eli in forum LCD/Display
    Last Post: 01-29-2005, 09:54 PM
  2. Computer Crashes When I hit a bump
    By antimatter in forum General Hardware Discussion
    Last Post: 12-15-2004, 12:33 PM
  3. message hit counter
    By edie209 in forum General MP3Car Discussion
    Last Post: 04-18-2001, 02:44 PM
  4. bump = reboot problem SOLVED
    By acitrano in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:37 AM
  5. wondering if ur dvd,cdrom, hd skip when you drive and hit a bump??
    By BobyYoo in forum General MP3Car Discussion
    Last Post: 11-29-2000, 02:41 PM
