Page 6 of 6 FirstFirst 123456
Results 51 to 55 of 55
Thread: Hit bump
  1. #51
    Jun 2005
    Maywood, Ca. U.S.A.
    I think I know what the problem is. With the force of the bump you might have damaged yor Hard Drive. Try inserting the Windows XP CD and if you see the "Press any key to boot from CD" message, its your HDD. Also try accesing the cmos. If you can get to your CMOS, its your HDD.
    Just my 2 cents
    Luis
  2. #52
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    that was already mentioned, please read the entire post
  3. #53
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I remember a buy who had a problem with his mobo touching the metal case when it flexed. Make sure you support it in the middle over a non-conductive surface.
    EDIT: ahhh hang on....I just realised this is that thread i think. I can't read the whole thread as my window is tiny as i am in work.
  4. #54
    Oct 2004
    Quote Originally Posted by justintime
    Hey titanium.. I assume the info you posted in this thread was the solution to your problem?
    If so, please update this thread to reflect solution was found!
    Sorry guys for not updating this thread. justintime is correct. The fix to my problem was within my Opus. After opening the case up i found that the metal case was the problem. The case was too tight.
  5. #55
    Raw Wave justintime's Avatar
    Apr 2005
    Awesome, thanks for confirming. I guess this 'closes the case'. (pun inteded)
    Quote Originally Posted by titaniumkingpin
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. Lilliput can't survive a bump anymore!!!
    By Rover_Eli in forum LCD/Display
    Last Post: 01-29-2005, 09:54 PM
  2. Computer Crashes When I hit a bump
    By antimatter in forum General Hardware Discussion
    Last Post: 12-15-2004, 12:33 PM
  3. message hit counter
    By edie209 in forum General MP3Car Discussion
    Last Post: 04-18-2001, 02:44 PM
  4. bump = reboot problem SOLVED
    By acitrano in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:37 AM
  5. wondering if ur dvd,cdrom, hd skip when you drive and hit a bump??
    By BobyYoo in forum General MP3Car Discussion
    Last Post: 11-29-2000, 02:41 PM
