Results 1 to 10 of 14
Thread: 2.5" IDE cable question...
    Constant Bitrate SamDude's Avatar
    London (UK)
    I'm receiving a error message that flashes for a second while the computer boots:
    "Primary IDE Channel no 80 Conductor Cable Installed"
    The cable used currently is a 40 pin to 44 pin IDE cable with a molex connector for supplying power to the HD.
    See image and details of existing cable here: eBay link
    I've had a look on eBay for an 80 pin cable, but none are suitable - they're all 40/44 pin (and not 80/44 pin, which means you can only use them with 3.5" drives??)
    The computer seems to work ok, although I've read that because of the non-80pin cable, it is causing a bottleneck in the performance I'm seeing.
    Any sources for the cable I'm after? Or do I just live with it?
    Have: Via Epia M10000 1GHz|512Mb|20Gb|Slim slot-loading DVD-R|Carnetix P1280|RevCam|GPS|Illum’d keyboard|11g Wifi
    Waiting for: Xenarc TFT in-dash (haha!)
    Status: Finalising component procurement
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Hi,
    from one Golf driver to another (and.. i own a triumph, so i have to support the british ;-)) i just googled for you, and this is the result:
    Both 40-conductor and 80-conductor ribbon cables have 40-pin *connectors*. Half the conductors in the 80-conductor cable are connected to one or more of the several grounded pins of the connector. That puts each signal conductor between 2 grounded conductors - shielding it from cross-talk and other extraneous bad stuff. They have different appearances, since the 80-conductors make 80 ridges along the cable instead of 40 ridges. See the following: http://www.pcguide.com/ref/hdd/if/ide/conf_Cable80.htm
    A temp. solution is to go into your BIOS and disable UDMA for your drives, this will reduce performance for those drive.
    - superbowl
    i never drink water cos fish ***** in it. (w.c. fields)
    Feb 2004
    I have a 44-pin IDE cable attached to the 44-pin Secondary IDE port on my Commell LV-671, and I too get the message on boot up.
    As far as I can tell, and also as Commell Tech Support has told me, this is normal.
    My 2.5" drive gets set in DMA mode when I start up Windows, so everything's fine.
    How long is your 44-pin IDE cable?
    Mine's short at 5", but you shouldn't have any problems with performance unless your cable is longer than about 12-18" inches.
    Jan 2005
    Germany
    Quote Originally Posted by Giuliano
    No, this is not normal. It depends on the type of harddisk you use which cable to select.
    - superbowl
    Feb 2004
    Quote Originally Posted by superbowl
    - superbowl
    There's a caveat with that - with 44-pin IDE 2.5" cables, yes, this is normal, as there are no 88-pin or 80-pin IDE cables for 2.5" drives.
    At least, none that I could find.
    For 3.5" IDE drives that do ATA/100/133, then no, that is not normal, and you have to use the 80-conductor cable for those drives.
    Of course, if it's such a bother, you can use a 40-pin 80-conductor cable, and use a 2.5" drive adaptor.
    Jan 2005
    Germany
    Fully agree ;-)
    - superbowl
    London (UK)
    @superbowl - thanks for your info. What I'm after is if a 80 pin (3.5" IDE) > 44 pin (2.5" IDE) cable is available (or not).
    The PC works fine, its just that I don't like niggling 'warning' messages.
    This must affect everyone who has a Mini-ITX based carputer and uses a 2.5" hard drive! So what's the fix? (apart from 'live with it').
    Feb 2004
    Quote Originally Posted by SamDude
    Well, supposedly the 80-conductor cable tells the IDE controller it's 80-conductors by shorting one of the pins to ground..
    So it may be possible to slip a piece of jumper wire over one of the pins to "trick" it to thinking it's an 80-conductor.
    I'll have to research that further, however, so don't go about trying it quite yet.
    Or in other words, "live with it"..
    London (UK)
    Would that not create a 'bottleneck' which reduces the performance where the 80 connectors reduce to 40?
    Jan 2005
    Germany
    Hi,
    there is no bottleneck, because in a 80 pin cable, there are still only 40 pins transmitting the data, the other 40 are for shielding only.
    I use a 2.5" disk with an adaptor... and a 80 pin cable (came with my mobo) and it runs fine !
    - superbowl
  1. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 01:16 AM
  2. Got my IDE > USB cable today.
    By d_sellers1 in forum Newbie
    Last Post: 10-05-2004, 01:40 PM
  3. 13 foot IDE ribbon cable?
    By cheerio in forum General Hardware Discussion
    Last Post: 08-24-2004, 01:59 PM
  4. Long (36") rounded IDE cable.
    By ddt in forum General Hardware Discussion
    Last Post: 05-07-2003, 05:30 PM
  5. IDE cable length
    By TheDingo in forum General Hardware Discussion
    Last Post: 12-02-2000, 02:08 AM
