Results 1 to 10 of 13
Thread: Ideal location for a temperature sensor??
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    I'm going to be using Road Runner in my car and need to place the temperature sensors both inside and outside my car. I'm wondering where the best places are to place these sensors where they will give accurate readings without being affected by sunlight, moisture, etc? My biggest problem is the sunlight which seems to send WILDLY inaccurate readings until it 'cools' back down.
    Where are the factory sensors located?? Are the insulated?
    Thanks for the responses.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    actually thats a very good question, I am about to mount a temp sensor outside of my car as well. I was thinking of somewhere around and underneath the trunk area, that way it wont get sunlight and it wont be affected by the temp of the engine. and I was reading somewhere that putting the sensor in to a small pipe filled with silicone would help even out the sensitivity.
    肚子笑痛了
    S60 Install
    Newbie XeroDSM's Avatar
    Jul 2004
    Blacksburg, VA
    I was thinking about where to put the sensors too and I was thinking that the in-car one should be pretty near your head, maybe on top of the headrest if you can fab it in there, if not I think under the dash above the pedals might not be a bad spot, just make sure it's not too close to anything blowing cold or hot air towards it.
    Low Bitrate Prem's Avatar
    Oct 2004
    West Sussex UK
    I have found that on the Peugeot 306 the external temp sensor is on the bottom of the passenger door mirror. Not sure if this helps, but thats where the factory put it!!!
    Prem
    Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
    Modified Sproggy PSU
    Custom made automatic start-up/ shut-down controller
    Dual 2.5" HDDs
    Laptop DVD Reader
    D-Link FM Radio
    5" PSOne LCD
    Installed and working. 75% complete.
    May 2003
    Miami, FL
    good info I am going put long wires on mine and see where I get the best results.
    肚子笑痛了
    S60 Install
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    yeh my factory temp sensor is located on the underneath of passenger wing mirror
    CarPC status: iPod, 3,456,217 songs so **** you
    Mar 2004
    Interesting place... wonder if this is where other cars keep them? Thanks for sharing. Is there any sort of insulation around the sensor?
    Progress Meter:
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    same in Renault cars.
    Quote Originally Posted by carpcnoobie
    Not really, just looks like a pimple made out of plastic lol
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    IIRC the focus one is behind the front bumper plastic
    edit: I could have picked something better for my 1000th post.. oh well
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 03:03 PM
  2. Real temperature solution - what do you think?
    By dmurray14 in forum Centrafuse
    Last Post: 01-24-2005, 09:38 AM
