How are you going to load the CD in the drive if its upside down in the 1st place?
Seems that the easiest way to mount my zpcgx is upside down( because of the cpu venting on the top ) I want to mount it under my rear deck. So, would the cd pop out if I run this upside down and sit a bump? hmm...
Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
get a laptop drive that "snaps" the CD/DVD in place... super cheap, you'll just need a laptop to IDE adapter (like $10)...
or mount the drive upside down in the case so it's right side up when you mount the case.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizard just a question, how so much debt???
The case/computer they are refering to has the slimline optical 5.25 inch drive bay. Depending on how they are mounted, the drives are not symetrical. There is a step on one side. I had to totally make new brackets when I turned mine over, and rethink the mounting it of. Tray loader if the CD snaps in should be okay, a tray that it floats on would likely be too much trouble. I would probably work on making a new bracket and flipping it over.
The drive is the snap in type so I may be ok.Originally Posted by Bangster
yes, I said the easiest way is to mount the entire ZPC upside down. I could mount the dvd upside down after figuring an entire mounting system for both the hd and the dvd drive. I already figured the wiring though.
I have an external dvd drive for the cabin and I want to keep one in the system for extra storage in the trunk. The drive to go in the trunk was ony $10 so I may just risk it.
Yeah, you're good.Originally Posted by crazymadbastard
I'M DEBT FREE!!
Hey crazymadbastard,
I mounted my zpc upside down in my trunk and its fine cd snaps in and out.
Check out the Pics HERE to see how I did it.
Deviser
In progress Carputer [////////||] IWill ZPCgx: P4 2.40Ghz, 512Meg, 40Gb, Xenarc 7" TSV, 5 1/4 slot DVD, 802.11g DWL-G132, Ebay BU-303 USB GPS, TMobile GPRS Internet, Custom made power controller.
HU-Alpine CDA-7897 Fantom Face XL AM/FM CD/MP3 Receiver.
Nice looking power supply - how much current can it supply?
