Results 1 to 3 of 3
Thread: Different Speeds of Ram?
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    Is it alright to put in different speeds of ram into a laptop? My dell currently has Pc2100 and I unknowingly thought it was PC2700 so i bought another stick of Pc2700. My question is... is it safe to use it? Can there be any damage done to the laptop? Thanks!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    i'd check with the crucial website as sometimes they list all the memory that will work - even adding the higher speed stuff that is wasted but will work. As far as i know you will just not be using the RAM to it's full potential die to the lower clock speed. I have run PC133 with PC100 ram running at 100mhz but thats all i have done as i don't have anythign that uses DDR as i have a flaming old PC!
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Mix and match, it will just run at one of its fallback speeds in common with both sticks of ram.
    Quick! To the Popemobile!
  1. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 07:39 PM
  2. REALLLY noobie question on RAM
    By tdevil in forum Newbie
    Last Post: 02-01-2005, 02:45 PM
  3. Fs: Ram, 160gb Sata Hd, Ibm Laptop
    By StratusPh34r in forum Classified Archive
    Last Post: 12-09-2004, 04:41 PM
  4. Morex 3688 RAM
    By SonicCobra03 in forum General Hardware Discussion
    Last Post: 06-01-2004, 10:25 PM
  5. upgrading ram on comp
    By cubanmoses in forum General Hardware Discussion
    Last Post: 07-28-2003, 02:53 AM
