Results 1 to 10 of 14
Thread: Help deciding on an EPIA board: 800 v M9000
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Hi all,
    Having been a dedicated mp3car head for a while, i recently got interested in HTPC building. So i am putting a project together, trying to build, into a DVD player's skeleton, a computer on which you will be able to watch TV, pause live TV, setup times to record stuff, and play DVDs. So it will function as an all-in-one, literally. I plan to install KnoppMyth on it and get a Hauppauge PVR-150 Low Profile on a riser card. My question is this:
    Should i get an EPIA 800 or M9000. Cost is sort of an issue, but i could afford either if necessary.
    The way I see it, the drawbacks of the 800 are:
    No USB2.0 (dont need it for this project)
    Weak CPU (PVR150 has an MPEG2 hardware encoder, so that wont be straining the CPU)
    No DVD decoder......is this a problem for anyone who has an 800?
    The M9000 has USB2 and a hardware DVD decoder. But it has a fan (noise?), is more expensive an an 800, and may not work as well with linux bios (any exp here?).
    I know lots of people on this board use mini-itx, so i thought i would see your opinions. If you are using either board, could you post what you use it for and how you like it? Thanks!!!!
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    If what you building is a carputer forget the fan noise I have 2 extra fans and I don't hear anything when driving coming from the PC
    Newbie meatwad's Avatar
    Jan 2005
    Evansville, IN
    Check with the Myth project concerning the onboard MPEG2 decoding of the M9000. I think they had it working but it might not be as easy as 1-2-3. That said, you might have to do some kernel tweaking and/or upgrading to get USB2.0 working with the Knoppmyth distro (I honestly can't remember if I had to our not, I flopped back and forth from Redhat 9, Knoppmyth, Sage on WinXp, and Fedora Core 1 and 2). Then again, being the Linux noob that I am, I could be completely speaking out of my a$$
    While I haven't run a barebones system in Myth like you are planning, I have been into that hobby for around 18 months. Knoppmyth is an excellent choice for out of the box use and should give you few problems. My only really sound advice? Storage... more than you plan on needing.
    Quotes
    "Meatwad makes the money see, Meatwad gets the honeies G..."
    Setup
    Complete = 20%
    Concept/Planning = 50%
    Purchased = ~$750
    Nov 2003
    Quote Originally Posted by meatwad
    Thanks for the advice. The HDD will be the last thing i buy, since if i buy it now it will be overpriced then. Do you think that the 800 will be able to run knoppmyth? I have almost 0 exp in linux, so this will be a learning project in every way. I recently built a new desktop machine with a PVR150, asus mobo, XP2700 - and half a terabyte of raid 0'd space. and im almost full!
    so yeah, any advice on the 800 would be appreciated.
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    DONT DO IT!!!!!!!
    the 800 can barly handle a divx rip let alone a DVD base don my experience there only good as low power servers mate
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Nov 2003
    Quote Originally Posted by Danceheaven
    DONT DO IT!!!!!!!
    What happens when you play a DVD?
    Thanks for the input!
    May 2002
    Essex, UK'er
    Quote Originally Posted by jusatry
    Choppy playback
    www.aimee.cc
    Nov 2003
    Choppy playback
    What OS were you using?
    May 2002
    Essex, UK'er
    that was on win xp sp1
    slimline toshiba 8x dvd drive with 256 mb of DDR2100
    using media engine
    ive got my epia 800 fired up here now mate it took an hour to install xp on last night and is very very sluggish with nothin installed yet so i dread to think what itll be like once ive got stuff installed
    www.aimee.cc
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Thinking about either the MII10000 or the MII12000 myself. P4 route sounds kinda tempting too, although I'd have to weigh it against the built-in extra connectivity of the MII's
    Dunno abouth the 800's though - I do know people are struggling to get rid of theirs.....
  1. FS: VIA EPIA 800 Mobo (2.of).
    By tailormadepc in forum Classified Archive
    Last Post: 10-03-2006, 04:32 PM
  2. VIA EPIA 800 Mini-ITX Mainboard (£50 incl. Postage).
    By buildfromscratc in forum Classified Archive
    Last Post: 07-26-2004, 05:52 AM
  3. FS: VIA EPIA MINI-ITX M9000 Board
    By Elmezie in forum Classified Archive
    Last Post: 05-16-2004, 04:01 PM
  4. Help with Epia 800 / pw60 / ITPS
    By lalo in forum Power Supplies
    Last Post: 01-04-2004, 03:39 PM
  5. VIA EPIA C3 800 BOARd MEMORY
    By jpainter99 in forum General Hardware Discussion
    Last Post: 08-29-2002, 10:53 PM
