Results 1 to 7 of 7
Thread: Has this happend to any of you?
    Feb 2005
    Question Has this happend to any of you?
    So I purchased a via TC10000 mother board and the proper NoN-buffered ram and put the rest of the hardware all together. Used a CarNetix to regulate the power and started everything up and i got nothing. I mean nothing in the way of no responce from the mother board. Hell the processor fan didnt even turn on. I proceeded to order another board and decided to hang onto the non operation board till I knew the new one was a good board. Believe it or not the next board did the same thing besides the processor fan did turning?!?! I even went and purchased a different type of ram and still nothing. After becoming very frustrated I decided to go with a MKII120000 board instead and powered it with the Opus 90watt. Did I miss somthing or is it possible to have 2 new motherboards be bad??
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That would be highly unlikely...but possible, I suppose.
    Did you check the voltage coming into the mobo with a digital multimeter to be SURE power was getting to the board? My first reaction would have been that I hadn't hooked up the Carnetix properly or the power switch wasn't connected properly.
    Want to:
    Feb 2005
    The power part was checked, and checked and checked. I went over it with a voltmeter quite allot!
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    I had this problem, but the opus(150) was blinking two quick pulses when acc was hot. Looked it up in the manual and the power on leads to the MB were reversed. I thought it was strange that it should matter since when I had it connected to a standard power supply I was turning it on by shorting the power pins with a screw driver. I think the opus sends a low power supply to one of the pins instead of actually closing the circuit like a normal switch. Probably not your same problem since you have used different power supplies and on switches.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I've had this problem with a different motherboard (Abit). Turned out it was bad RAM. I would strip everything down to a minimum and try different RAM and a standard ATX PSU.
    Feb 2005
    tried to sets of ram and 2 motherboards. still no luck so i decided to go with another mother board and power supply set up. All works fine but I'm still confused why we couldn't get the first set up to work..!
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    did u try powering it with a standard atx power supply or just the opus?
  1. What ever happend to...
    By PoBoy in forum Off Topic
    Last Post: 06-16-2003, 11:32 PM
