Results 1 to 10 of 16
Thread: COM port problems. VIA MII
    Dec 2004
    Long Island, NY
    I have a VIA MII mobo and it wont detect my COM port. When i go to the device manager it says the device can not start.
    I can't find driver for this.
    any suggestions?
    thanks!
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    make sure ALL the Via drivers are installed from CD
    Dec 2004
    Long Island, NY
    ok, i tried that but still nothing. what else can i try?
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    You have it enabled in Bios, right?
    2005 Ford Focus ST
    Dec 2004
    Long Island, NY
    where would that option be under?
    Dec 2003
    Portland, OR
    while booting up the PC, press the delete button a few times (right when it reports the memory and drives and such, black screen)
    You will come to a blue Bios screen..select SuperIO Device, and make sure the serial port is set to Auto
    2005 Ford Focus ST
    Dec 2004
    Long Island, NY
    Thanks for the help.
    I went into the bios. It wasn't disabled but it was set to one of the other choices. I set serial port 1 to auto and serial port 2 to auto. I went into the Device Manager and it showed two com1 ports (both not working), I changed the second com1 port to com2 and still the same thing.
    Any other usggestions?
    Oct 2004
    s.cali
    i kinda had this same problem, all i did was uninstall the drivers and disabled them, then reinstalled the 4-in-1 drivers and reinstalled the ms ones too and both ports work fine for me now.
    Progress: | All materials Purchased...
    Dec 2004
    Long Island, NY
    how did you reinstall the ms ones? with the windows cd?
    I re-installed 4-1 and i get two com1 ports. Is it supposed to be like that? before it would show com2 and com3
    Dec 2004
    Long Island, NY
    when i got into the fisrt com1 port this is the conflit device list:
    i/o range 03fc - 0403
    IRQ: 15
    Input/Output Range 03FC - 0403 used by:
    Motherboard resources
    Communications Port (COM1)
    Interrupt Request 15 used by:
    Secondary IDE Channel
    second com1 port shows the same
  1. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  2. epia MII 12000 shipping problems?
    By theheel in forum General MP3Car Discussion
    Last Post: 06-01-2004, 09:13 PM
  3. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
  4. Serial port problems in XP
    By Maveric in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:25 PM
  5. LCD parallel cable Cross Talk and/or port speed problems?
    By digital chaos in forum General Hardware Discussion
    Last Post: 12-20-2000, 09:48 AM
