Results 1 to 10 of 16
Thread: Cool new toy I got (USB enclosure for slim DVD/CD drive)
    FLAC SFiorito's Avatar
    May 2004
    Okay, I did a quick search so I don't think anyone has posted about one of these (this specific one I mean) before.
    http://www.shentech.com/suusb1excaen.html
    External USB enclosure for slim DVD/CD drives. It plugs straight into the back of the drive, no laptop->ide->usb run-around and the drive is powered over the USB bus. I just tested it out by playing a CD on my laptop from the drive. Cool ****. Seems like a good way for molding the drive into the dash since the case is exactly the size of the drive and you can run the cable to your case without need for a power adapter. If you want to use a power adapter it comes with a PS/2 or USB power adapter. I put my slim slot load DVD in it and I'm planning to hopefully have it in my dash or I may go ghetto and just put it in my armrest.
    *EDIT*: Forgot to add: I've been looking at those new "palmtop" PC's. This would be a good way to add a DVD (or CD-RW whatever) to one since it's powered off the USB bus and it's small enough to fit in any bag.
    Mar 2004
    Bay Area, CA
    How long is the included usb cable?
    May 2004
    USB cable is 26" / 66cm
    Power cable is 33" / 84cm
    Jan 2005
    i got one and works great...
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    it does work good however the case is plastic i believe and veryyyy cheap.
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    I have one, and just an fyi you will want a power adapter that will give you 1.5 amps. The requirements of most laptop cd drives. Your usb port will only provide 500ma. Just a thought anyway.
    I have problems with it not being able to play or read a cd for any period of time. Works great for short burst of info, but once I put on the demand (a DVD or Divx movie) it get's real choppy and sometimes just craps out. I added a power adapter and all my problems went away. Viola....
    You can still have something if you have nothing
    May 2004
    i've been playing a dvd on it without problems... you sure it's not that you've got it plugged into a USB 1.0 port?
    Jan 2005
    here is a pic, i have a usb power hub, i had the same problem but all set with the hub
    Maximum Bitrate knubile's Avatar
    How did you guys power it? What PSU are you using?
    May 2004
    I ran a DVD for almost 30 minutes straight just off the USB cable (no extra power adapter) without problems. Windows Device Manager registered it as pulling 96mA. Not sure how accurate that is. In comparison my Sony Bluetooth uses 250mA.
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 11:50 AM
  2. FS: USB hard drive enclosure
    By Alives in forum Classified Archive
    Last Post: 06-11-2002, 05:16 PM
  3. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
  4. External USB drive
    Last Post: 11-27-2001, 05:25 AM
  5. How about a BUSlink's Portable USB Hard drive ?
    By percyt2k in forum General Hardware Discussion
    Last Post: 05-25-2001, 08:47 PM
