Results 1 to 5 of 5
Thread: PCI Extension and Graphics Card Hook UP
    Nov 2003
    Florida
    I have the Via M10000 motherboard and I built its case to fit into a small space in my car. But now I have an extra sound blaster to hook up to it and an extra nvidia graphics card with dual monitor out to hook up to it. But I need to put both of them about 2 feet away from the motherboard. What can I buy/make to extend the PCI connection to the sound card, and is it possible to hook up an AGP card to the motherboard (also at an extended distance)?
    -=Chevy CarPC=-
    ETA: When i get more time
    -Custom Fiberglass Case
    -Epia M-10000 Nehemiah 1Ghz
    -Sony CDRW-DVD Drive
    -Seagate 120mb Hardrive
    -Opus 90w Power Supply
    -Lilliput 7" LCD
    Raw Wave tj!2k4's Avatar
    Oct 2004
    http://www.baber.com/cases/1u_2u_risercards.htm
    Edit: I bought 2 PCI riser cards from them. Their order form is ghetto because you have to manually enter the part#, desc, price, etc. but they did ship very quickly.
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    what do i need to look for in riser card specs?
    [4Runna]
    next - wifi
    Oct 2004
    Figure out if you need a solid/pcb or ribbon riser, and make sure you understand which way the PCI/AGP connector on the riser card faces when installed..
    Dec 2004
    NY
    i saw stuff about volts and bits?
    is that like kibbles and bits?
    [4Runna]
    next - wifi
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 01:59 AM
