Results 1 to 10 of 18
Thread: Epia Motherboard GCS Capacitor Issues
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Exclamation Epia Motherboard GCS Capacitor Issues
    Hey, all. Majorly bummed that my shiny new M10000 is doomed to [what I see as] a short life.
    I've started this thread to alert everybody to a known issue with the [cannister] capacitors on Epia mainboards. Props to Mick for the heads-up.
    In a nutshell: Via's been using el-cheapo capicators labelled "GCS" on some of their motherboards, and they have close to a 100% failure rate.
    From what I've read, Ms, MIIs, and CLs are definitely affected. Wonderful.
    References:
    bad capacitors on VIA EPIA boards?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    If you dig in deeper many sites and articles mention that even the most known manufacturers of screens and mobos are suffering these problems...
    It is not a question of el-cheapo at all (from my view)... It is a question of a flaw in the product, which was not discovered in time (basically what would cause your Mercedes-Benz/BMW car to be recalled - not meaning it is a cheap-o car) and the dimensions of the problem, and the size of the spread became so huge that it became impossible to recall all the deffective products.
    HOWEVER, from what I have read the caps tent to malfunction only in very heavy duty cycles (like 24hrs on), and/or bad cooling (not sure about the fanless versions)... so basically dont leave your carpc on 24hrs a day, and think about cooling when u design your case/system... I think you can be tranquil on this issue, afterall, I havent seen any complaints in this forum, but I have seen issues raised from other types of applications like servers/PVRs that would be always-on...
    Feb 2005
    Quote Originally Posted by RoyN
    Maybe. But I somehow think that the GSC (aka contraband formula) caps were more cost-efficient for Via. I don't blame them for trying to keep prices down; this possible (pending?) failure just really irritates me. What I do blame them for is not acknowledging this problem. I guess all the boards would've been too expensive for them to recall, poor guys. So people are ending up $200 paperweights.
    ...I think you can be tranquil on this issue, afterall, I havent seen any complaints in this forum...
    /hopeful, but soldering iron in hand
    Aug 2004
    Suprising that VIA let this happen... especially after all of the bad publicity and such that Abit got for the same thing a few years back...
    http://www.spectrum.ieee.org/WEBONLY...eb03/ncap.html
    Constant Bitrate faichiu's Avatar
    GSC is very poor capacitor.
    98 Honda civic
    In-Dash LCD Monitor K-301
    cappuccino EZ3
    PIII-1.2GHZ
    256MB PC133
    40GB HD
    Holux GR 213 Sirf Star III GPS
    IguidanceV2
    CNX-P1900 power supply
    Sound Blaster Live USB
    São Paulo, Brazil
    I'm not sure how sourcing for this kind of stuff happens, but I have read that even the largest mobo manufacturer in the world PCCHips or whqatever its called, had problems with their caps... and from my understanding it wasnt only GSC brand caps that had problems - i could be wrong though...
    Anyways, it would not be viable for VIA/PCChips/and a ton of other companies to recall products manufactured one or two years earlier...
    Anyways, there is a mention that the newer boards are no longer being fit with these components anyways so take a look at yours...
    Like has been pointed out... it is a function of heat vs uptime, so Ireally doubt problems to be very significant to our crown... Heck, the problem has been out for yrs and I hadnt yet seen any complaints about it on here....
    São Paulo, Brazil
    After reading that entire article it now appears that GCS itself isnt the only manufacturer affected, and that GCS itself might not have known of the problem, and most certainly VIA and the others didnt even imagine this...
    The fault is in a component of the capacitors sold by yet another company.... all this info is in the link posted up...
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    well if it happens to us cant we just remove them and solder new ones on?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    São Paulo, Brazil
    I think you can DEPENDING on the extent of the "blow-up"... sometimes it can crap out the mobo by shorting after the blowup...
    hmm maybe i should add a few more air vents in my set up haha.
    1990 Jeep Cherokee
  1. VIA EPIA MII 12000 1.2Ghz Motherboard questions
    By arise360 in forum General Hardware Discussion
    Last Post: 12-30-2004, 02:38 PM
  2. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  3. Epia vs. Regular Motherboard
    By jnusaira in forum Newbie
    Last Post: 02-09-2004, 09:49 PM
  4. FS/FT: Via EPIA 800 Mini-ITX motherboard including 128mb PC100!
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 12-19-2003, 02:54 AM
  5. Check out this epia motherboard!
    By Mitokondria in forum Off Topic
    Last Post: 05-08-2003, 09:16 AM
