Results 1 to 10 of 10
Thread: VIA EPIA locks up w/USB DVD drive
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I've got a via Epia M10000, sometimes it'll boot and sometimes it will lock up at the POST. I'm wondering if anyone has has this issue ?? I haven't updated the BIOS to the new version but I'm going to take the PC out of my car and try it.. the thing that bothers me about VIA's site is that it doesn't tell you what changes they made or fixes the new BIOS has... It's very frustrating...
    Edit: The reason why it's locking has something to do with the USB dvd player because immediatly when I unplug the DVD player it'll boot up..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Feb 2005
    Yea this is a tough one. If you've narrowed down the problem to your USB port, I would usually recommend a BIOS update. But, ff you've already tried that, then try to ENABLE USB LEGACY SUPPORT in your BIOS. USB can be REAL flaky at times.
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    I have the same problem, but haven't overcome it yet. Theres next to no USB options in the BIOS for the M10000.
    If i find a cure i will let you know, but if you find a cure - please let me know.
    We are, will have and forever will be...
    But not tommorrow!
    Feb 2005
    You might also try and update the FIRMWARE on your drive....
    There's a good chance it doesn't play well with certain chipsets and firmware upgrades are readily availabe on the manufacturers website.
    Jul 2003
    Try plugging it into one of the USB headers on the motherboard. So far it seems to be working for me.
    But not tommorrow!
    Jun 2004
    NH
    Thanks for the suggestions, You know I never even thought of a firmware update on the CD drive.... I'll keep you all posted...
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    Jun 2004
    NH
    Yup, none of these suggestions have worked aparently my DVD device doesn't have firmware (Addonics Pocket Drive DVD-CDRW) I've confirmed this with addonics. I've updated my systems BIOS to 1.35 (Via EPIA MII 10000) I'm contacting VIA next but this really is a bummer 230.00 DVD drive and its probably not "compatible" with this system board... GRRRRRRRRR
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    _
    Mar 2004
    Little Elm, Texas
    Did you find out what the problem was here?
    Asking because another user is having a similar issue: DVD Drive Boot problems
    Jan Bennett
    Jun 2004
    NH
    Yes
    The problem was because the USB ports on the VIA board were not supplying the drive withthe correct amount of juice.. I never used the drive again.. What a waste of money..
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    Jul 2003
    I've been using a Panasonic slot-load dvd drive that has a loopback USB connector for extra power and has ben working fine. I don't know if you can buy those sort of cables by themselves, but it may solve your issue and enable you to use your drive again.
    But not tommorrow!
  1. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 01:16 AM
  2. DVD Drive Horror!
    By c0rrupti0n in forum General Hardware Discussion
    Last Post: 10-30-2004, 04:30 PM
  3. cover for a slim slot loading dvd drive?
    By fasternfaster in forum Fabrication
    Last Post: 10-08-2004, 06:51 PM
  4. problems mounting dvd drive vertical ?
    By robert42 in forum General Hardware Discussion
    Last Post: 09-07-2004, 09:44 PM
  5. Any info on this laptop dvd drive
    By tapper1999 in forum General Hardware Discussion
    Last Post: 01-15-2002, 04:54 PM
