Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: High output LEDs?
  1. #11
    Jan 2005
    This is the center console above the rear view mirror. There are 3 bulbs, one in each of the black areas, and one in the middle. It measures about 20mm across.
    This is one of the floor well lights, it measures 8mm across
    This is one of the rear passenger reading lights, it has two lights, it measures about 5mm tall.
  2. #12
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    A note about cd: candellas are a unit of intensity, and not light output. So a 10cd LED with a 30 degree viewing angle would output the same amount of light (lumens) as a 5cd one with a 42 degree viewing angle (I think I got the math right).
    Now, which should be of greater concern is up to you; I would think that a targeted light such as a reading light you're concerned about the candellas (as long as the angle is sufficient), while a flood light like the floorwell you'd be more concerned about lumens (and may what to use a diffuser to spread out the light)
    edit: ah, pictures! Looks like you already have a diffuser on the floor lights.
  3. #13
    Jan 2005
    The LEDs on ebay all have viewing angles of <10 deg.
    lsdiodes.com has 5mm ones with 20deg.
    If I cut the domed part off, wll the viewing angle increase significantly?
  4. #14
    Aug 2004
    SE Michigan
    I'm not sure how much the domed enclosure is involved in focusing the light. But the reason the ebay LEDs have so little viewing angle is that they are cheap - or rather, narrowing the beam is a cheap way of pumping up the mcd rating, which is the only thing alot of people seem to pay attention to.
    edit: come to think of it, I don't think the dome focuses the light at all. Lightly sanding it is a common method of diffusing the light though.
  5. #15
    Jan 2005
    So which LEDs do you recommend that I get? and how many for each of the three pictures I posted? Thanks.
  6. #16
    May 2004
    Denver
    e46 3 series... easy spot...
  7. #17
    Jan 2005
    DUH hahha jk 2004 325i
  8. #18
    Aug 2004
    SE Michigan
    I'd probably go with the sflux for the floods, and 5mm for the task lights. Hard to say how many - really, just get a handful to play with and test out, and then make a informed decision on the exact type and number to use.
  9. #19
    Jan 2005
    How can I visualize how bright 10,000 or 20,000 mcd is?
  10. #20
    Low Bitrate Vacheron's Avatar
    Jan 2005
    Newcastle UK
    Quote Originally Posted by mushin
    Yes, it is the shaping of the parabola of the cathode inside the device that performs most of the shaping on a 5mm device. Though some very wide angle 5mm have the dome cut off as it can attempt to refocus the beam. The Superflux devices alter the distribution using the dome though.
    just get a handful to play with and test out.
    I would definately second that suggestion as lighting is such a personal and subjective thing. As 5mm devices are the easiest for the novice to mount (and can be bent into different positions much easier) I would get about 20 and just play with them!
    PS, Go for Nichia if you can get them. They rock!
    I have one or two right next to me here but unfortunately, getting them to you would be tricky!
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 02:48 PM
  3. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 08:10 PM
  4. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 11:19 AM
  5. Car Alarm Aux output and Shutdown controller
    By MatrixPC in forum Power Supplies
    Last Post: 05-09-2004, 07:36 PM
