Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: High output LEDs?
  1. #31
    Jan 2005
    OK I installed two areas.
    I had to put 7 LEDs into the map lights because their viewing angles are so small.
    What LEDs have a greater viewing area?
  2. #32
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by phita23
    Pics?
  3. #33
    Jan 2005
    You're killing me here! I just settled down too. Give me a few mins I'll go.
    So what LEDs have very wide viewing angles? I tried cutting off the tip of the LED it just made the light dimmer and not noticebly wider.
    The LED's I have installed have a very small viewing angle. I can look right into the hole where the lights are, and it will seem like one or two of the lights are burned out. But when I move my head around, all of a sudden the "burned out" ones will blind me.
  4. #34
    Jan 2005
    I'm in the middle of replacing my interior lights with pure white LEDs.
    Suggest some wide angle LEDs for the areas that need a wide area of light cover.
    In each hole, I have 7 12000MCD led's with 20deg viewing angle.
    I like the color better than stock.
    with the led's on
    with the led's off
    this is the new color
    this is the stock color
  5. #35
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    The previously mentioned sflux's have a 45 degree viewing angle...
  6. #36
    Jan 2005
    Quote Originally Posted by mushin
    Would one be sufficient in the middle light (still a incandescent bulb in the above pictures)?
    Any ideas how I could fit more than one in there?
  7. #37
    Maximum Bitrate DeltaFX's Avatar
    France
    Use luxeon leds.
  8. #38
    Nov 2004
    Cali
    Quote Originally Posted by DeltaFX
    Use luxeon leds.
    Did you see the price on those? And the size? might be a tight fit. But you are right, those things are ridiculously bright, one of my friends used them for a project, and all he told me was "it's an LED" before turning it on, blinded the hell out of me
    I have found you an argument; I am not obliged to find you an understanding.
  9. #39
    Jan 2005
    Use luxeon leds.
    Where can I buy them? It's true that they're quite expensive. lsdiode doesn't have them, and ebay has a very limited supply.
  10. #40
    Nov 2004
    Cali
    Just do a search online, i came up with several stores that were selling them for about 12.50/each.
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 02:48 PM
  3. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 08:10 PM
  4. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 11:19 AM
  5. Car Alarm Aux output and Shutdown controller
    By MatrixPC in forum Power Supplies
    Last Post: 05-09-2004, 07:36 PM
