Results 1 to 10 of 15
Thread: HELP QUICK!! CPU Fan ??
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Question HELP QUICK!! CPU Fan ??
    Hi All,
    Ok, I got everything in order tonight and turned the power on for the first time. It went to post with a single beep which I think is good (right?), but the fan that is on top of the heatsink did not turn on. It only has on 3 pronged cord coming off it (black, red, yellow) which I plugged into the CPU fan on the motherboard. I turned the computer off right away so that I don't fry anything.
    Does the CPU fan go off and on by itself, or should it be on all the time? Should I try powering it on longer to see if it comes on?
    Thanks for the help!!
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Low Bitrate cletus323's Avatar
    Oct 2002
    Maryland
    The CPU fan should be running, even if only at low speeds, whenever the computer is powered on.
    FLAC edrex's Avatar
    Dec 2004
    Not what I wanted to hear, but thanks for the reply. Now I need to do some troubleshooting.
    Anyone have some suggestions on where to start?
    Oct 2002
    Maryland
    Not sure what all you've looked at, but make sure it's plugged in correctly to the fan header on the motherboard.
    Do you have another pc that you can plug the fan into on one of the auxiliary fan headers to see if the fan works at all?
    FLAC edrex's Avatar
    Dec 2004
    Yes, but it's a b**ch to get the heatsink off. If all else fails, I'll try that tomorrow. I rechecked the plug, and it seems fine.
    FLAC edrex's Avatar
    Dec 2004
    Ok, tried some more stuff and got it working now. Thanks for the info Cletus. It just needed a little jump start!
    Oct 2002
    Maryland
    Any time!
    Just make sure it isn't gonna need a jump start once you put the case door back on
    Processor no likey
    FLAC edrex's Avatar
    Dec 2004
    UPDATE:
    So it was working just fine for a while. Then the fan turned off. Then it won't restart when the computer does. The CPU temp was about 120 degrees F. I am done trying to mess with it for the night. I got the OS (WinXP) loaded and that is working fine. Will get this fan thing worked out tomorrow...
    Any suggestions would help. Thanks.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    A long shot but try unplugging the fan from the mobo and reversing it. Is this an Epia?
    Want to:
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    get a new fan.
  1. which quiet cpu fan for m-athlon
    By mpfjr in forum General Hardware Discussion
    Last Post: 01-08-2005, 01:38 PM
  2. Quiet CPU heatsink and fan.
    By schapman43 in forum General Hardware Discussion
    Last Post: 12-25-2004, 12:09 PM
  3. CPU Fan
    By TimStark in forum General Hardware Discussion
    Last Post: 11-17-2004, 05:07 PM
  4. Quick question about CPU Fan voltage..
    By tbird2340 in forum General Hardware Discussion
    Last Post: 11-15-2004, 11:19 AM
  5. Monitor CPU temp, Fan RPM's and Volts via LCD
    By mp3bobo in forum Software & Software Development
    Last Post: 07-03-2000, 10:37 AM
