Results 1 to 4 of 4
Thread: The Ultimate In-car entertainment System
    Mar 2005
    I was looking at
    Except I think I can make mine cheaper!
    1) Toshiba 2805-s603 laptop in the boot (with the battery removed and the power swich held down by a matchstick it powers on automatically when power is administered).
    2) XDC01 in car laptop power supply which is compatible with 1)
    3) 7 inch tft vga touchscreen
    I hope to put all the equipment in the boot of the car.
    I already own the laptop and the rest above add to 330 euros.
    Now for my questions.
    i) I assume All I need is a very simple cheap amplifier to connect the headphone sound out of the laptop. Can u recommend something small and cheap and available within the uk or ireland?
    ii) I assume the screen doesn’t need a regulated 12v supply- just the same power as goes to the radio?
    iii) have I got enough alternator power to drive all this equipment when the car is turned on?
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Mar 2005
    i havent got it done yet!
    im in the planning stages only and need advice as to wheter this setup is viable
    Newbie joedavenport's Avatar
    Feb 2005
    LA, CA
    Quote Originally Posted by damo642
    ...the power swich held down by a matchstick...
    You may want to reconsider using matchsticks to build your project.
    Don't skimp on your amp, look at distortion ratings, then compare price. Check your manual or call the dealership to find the current output rating of your alternator, you will probably be fine unless you have a huge amp. If your headlights do not dim with the music at night, don't worry about it.
  1. new security system for the car
    By Cartunes in forum Off Topic
    Last Post: 11-10-2004, 06:36 PM
  2. Sound system and car tech
    By themp3son in forum Newbie
    Last Post: 10-25-2004, 12:00 PM
  3. Building Smart Car System, need advice, help
    By BugNuker in forum Newbie
    Last Post: 08-04-2004, 08:16 PM
  4. Connect hand held MP3 player to car audio system?
    By jasonwood in forum General Hardware Discussion
    Last Post: 10-30-2001, 11:30 PM
  5. psx game copying for car system
    By nyconx in forum Software & Software Development
    Last Post: 01-29-2001, 02:52 PM
