Could I just use this to convert the M1-ATX plug to fit to the Xbox?
http://tribemods.com/cgi-bin/store/s...=2493933_99927
Originally Posted by JBCrash
Designed by barusan over at www.xbox-scene.com
The main reason the guy wanted me to change his was because the inverter was putting lots of noise on the video signal. Using the DC-DC power supply stopped the interference.
Its more efficent and you dont need to get a shutdown controller for the inverter, coz the M1 handles all that!
Oh and the factory PSUs melt and burn your car down......... why else would microsoft be sending everyone a new power cable with a huge RCD in them!
someone want to build me a box that can do all of above? I like it!
1992 z71 Chevy
Yeah, the trible mods thing is basically that circuit,
I built my own, coz I couldnt be bothered to wait for one to be shipped from USA!
So will the M1-ATX allow the xbox to automatically turn on and boot up as soon as I turn on the car without the need of hitting the Xbox power button?
Where is the best place to buy an M1-ATX for a US customer?
Also....did you install the M1-ATX inside the factory Xbox case or did you build the Xbox into a custom case?
bump!
Yeah the M1 fits into the xbox alright, heres a crappy photo i took with my webcam!
The little brown board is the circuit i made from the schematic above.
For the setup i used the xbox did not need to be switched on with the ignition but it would be easy to add, it would be a case of wiring the m1 to power switch of the xbox! Have a look in the forums and at the tutorials over at www.xbox-scene.com , look for one on adding an external power switch, but instead of having a switch just connect it to the m1 (the output that normally connects to the PC power switch).
I dont know where to get the M1 since im over in the UK, but a good place to get the parts for the schematic above is www.mouser.com
Thats awesome. Thank you so much Pilt. I'll be ordering an M1-ATX (probably from mp3car) Do you have an email that I can contact you at if I have any more questions that I need answered quickly?
Also, how do you suggest that my Xenarc LCD be wired to the M1?
Well I am all done with the project and it looks and works GREAT! Now it's for sale so I can move onto another project I've dreamed up![]()
Selling Complete Xbox Car System w/ Xenarc LCD!
