Results 1 to 10 of 12
Thread: What can i mount my motherboard (or other PCB) on?!?!
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    What can i mount my mobo directly onto that will not need standoffs? I know styrafoam is out of the question because of static charge - but space is an issue, and i could use that 1/4".....seriously.
    Any ideas? A thin layer of plastic safe? I got some ESD mat (electro static dissapation i think), but that is 1/4" thick.....which sorta defeats the purpose....
    Thanks.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by jusatry
    Thanks.
    You could use nylon washers and just get the board a little tiny bit off the circuits.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Elsewhere
    Why don't you want to use standoffs?
    Personally, I'd suggest a piece of MDF with standoffs mounted in it.
    You don't want the motherboard to lay flat on anything, hence the use of standoffs. Also, the standoffs will be give you something to connect to ground, if needed.
    How about the Wiki?
    Nov 2003
    Quote Originally Posted by DarquePervert
    I dont want to use standoffs because i am trying to make this as low profile as possible. So if i use standoffs i also need that piece of MDF. thats more space than i would like to give up, if possible. Partially this is for another project, which is not carputer related but also requires a PCB be mounted in a very small place.
    Any ideas other than standoffs?
    Nov 2003
    Quote Originally Posted by J187
    what do you mean? with the standoffs or with some other kind of screw?
    FLAC J187's Avatar
    Nov 2004
    Boston
    No I mean instead of standoffs. Nylon washers could space the board up a little bit but not as much as standoffs classically do. Nylon washers come in all thicknesses, just choose whatever size and thickness lifts the board up enough.
    Please help.
    Constant Bitrate Phobos0001's Avatar
    Dec 2004
    Melbourne, Australia
    erm... i could be wring on this but dont PCB's especialy motherboards need some clearance because they need the nice cool air under them?
    Nov 2003
    Quote Originally Posted by Phobos0001
    hrmmm....i hadnt thought about that explicitly but i assumed that heat sinks and my HSF would do a good job cooling....and that heat rises so i would be okay.
    Mar 2005
    Depends on the type of proc. Just get some ESD (Electro-static-discharge) safe bags from a local tech supply store. They'll be really thin and will protect from what ever surface you mount them to.
    1995 Crown Victoria (P71 Police Interceptor)
    AMD Athlon XP 1900+
    256mb PC2100 DDR
    40gb Maxtor HD
    XM Direct
    BU303 GPS
    7" TView
    Frodoplayer & iGuidance 2.0
    Mar 2005
    I plan to mount it all on a small piece of plexi bought at home depot. It's about as thin and light as you can make it, and it'll look nice if you keep it neat.
  1. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 04:31 PM
  2. Mount motherboard over hard drive?
    By gambit32 in forum General Hardware Discussion
    Last Post: 08-19-2004, 12:47 AM
  3. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  4. Looking for an arm mount system
    By carpal tunnel in forum LCD/Display
    Last Post: 02-21-2004, 05:04 PM
  5. Replies: 0
    Last Post: 07-14-2003, 04:12 PM
