Results 1 to 10 of 11
Thread: Horrible Sound from VIA M10000
    Mar 2005
    Question Horrible Sound from VIA M10000
    Just started putting together my carputer. I have the M10000 motherboard and am running XP Home SP2. I've been through 3 Windows re-installations, multiple drivers, and more googling than I can handle. THe problem I have is witth the sound output of the line out. I'm not expecting hi-fi but I'm having serious problems. All I can get is buzzing, changing the balance to one side does help a little. Do I have a bad motherboad? Any ideas. Thanks in advance.
    Tim
    Thats very odd because from what I have heard of mine they sound great. I would take a guess that it may be a bad board. Don't take my word alone wate for some more people to chime in on this.
    Mar 2005
    That's what my googlin showed, what I'm experiencing is not typical. The sound is like the sound you hear when you touch two speaker wires together so maybe theres a short somewhere, tried checking for one with a multimeter but didn't really find one.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    you checked your cables?
    and your speakers?
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Newbie mxl4729's Avatar
    Dec 2004
    westwood
    ground loop. how are you powering the computer and were does the sound go after it comes out of the card. add a ground loop isolator and it shoudl clear everything up
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    Plug a set of known good headphones into the jack and see if the problem goes away. If it doesn't then I'd say send the board back.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have the same board and it sounds clear. The audiophiles don't like it but it sounds just fine to me. Try the headphone trick. If it sounds clear then YOU...HAVE...A....GROUNDLOOP.
    Search terms: "groundloop" or "ground loop"
    Want to:
    Newbie martymoe's Avatar
    Jan 2005
    Dallas Area
    i have an m10000 and i'm having the same problem it sounds terrible.. i finally gave up and put a usb sound card on it, (hoping somebody would figure out how to fix it..)
    m2
    Mar 2005
    Right now its powered by a Radio Shack CB power supply (13.8V) connected to a 200W snap-on DC-DC converter. My experience with ground loops in sound equipment has always been a subtle hum, not the static sound I'm experiencing. I'll look into it though. I've tried desktop speakers, headphones, and a FM transmitter, all have the same problems and work well on my laptop.
    I really prefer to not go with a seperate sound card, I've used all my USB ports and want to save the PCI slot for a TV tuner. Thanks for the help everyone.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Soooo...I've seen this sound problem mentioned several times recently but not before that. I'm wondering if there's a batch of bad Epia 10000's out there?
    Did you check the via forums to see if others have reported this problem?
    Want to:
  1. Horrible Sound
    By lgbr in forum FrodoPlayer
    Last Post: 10-24-2004, 02:57 PM
  2. PCI Graphics or Sound card - EPIA M10000
    By ZimZimmer in forum Newbie
    Last Post: 08-05-2004, 11:02 PM
  3. No sound on M10000
    By XtremeX in forum General Hardware Discussion
    Last Post: 01-07-2004, 05:20 PM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  5. epia m10000 sound quality
    By hijinks21 in forum General Hardware Discussion
    Last Post: 06-05-2003, 06:07 PM
