Results 1 to 8 of 8
Thread: usb to ide no workie
    Feb 2005
    I hooked up my usb and to IDE laptop HD and for some reason windows wpon't recognize does anybody have any suggestions as to what the problem could be theres no software to install it says that win xp should just pick it up please help me out!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Are you CERTAIN the cable isn't plugged in upside down?
    Are the master/slave jumpers set properly?
    Want to:
    Dec 2003
    Surrey, BC, Canada
    ^*not to steal the thread, but what should the master/slave jumper be set to when using a device like this? I've never used a usb harddrive before...
    To the poster, are you sure the drive is working? Have you tested it over ide? Also, can you hear the drive spinning/lights blinking, or is it not even getting power?
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    In that picture, I don't see the red LED on or the power supply lit up... lol... um make sure that's plugged in!
    If the power is working, you'll hear the drive spool up and start functioning whether it's plugged into pc or not...
    If that's all good.. then follow Bugbyte's suggestions... check cable and make sure it's set to right jumper...
    I know my external drive needed to be set to cable select to function properly.
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
    Dec 2003
    Surrey, BC, Canada
    Quote Originally Posted by Squid
    either my screen is not clear or it's just too late at night for me but I don't see any LED on the power supply...
    Jan 2004
    Pittsburgh, PA
    I think the LED is in the upper right corner of the PS... mine is almost just like that...
    the LED is flush mounted in the power supply... but maybe that's just a smudge on his.
    ...heh...
    CarPuter Install
    Raw Wave
    Jun 2004
    On the beach
    The power supply should be obvious as its a bright blue LED.
    Jan 2004
    Pittsburgh, PA
    Ah, well mine was a dull green!! It was just a cheap knockoff usb to ide adapter...
    Sorta assumed they were all similar...
    Man it was just a suggestion lol... u'd be amazed at the simple things peeps forget to check!
    CarPuter Install
  1. Slim DVD & IDE to USB - DVD QLTY
    By ZimZimmer in forum Newbie
    Last Post: 01-19-2007, 06:37 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. DVD Rom IDE to USB, 25ft. would it work?
    By mattress in forum General Hardware Discussion
    Last Post: 02-04-2005, 04:03 PM
  4. Got my IDE > USB cable today.
    By d_sellers1 in forum Newbie
    Last Post: 10-05-2004, 01:40 PM
  5. Ide 2 Usb
    By arkadiyp in forum General Hardware Discussion
    Last Post: 04-06-2004, 08:40 PM
