Results 1 to 10 of 10
Thread: how to install this?
    FLAC djmickyg's Avatar
    Feb 2004
    with alot of older programs. when i install em this window pops up an di cant install..
    why is this? and how can i install?
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    "But I don't want to go among mad people," Alice remarked.
    "Oh, you can't help that," said the Cat: "we're all mad here. I'm mad. You're mad."
    "How do you know I'm mad?" said Alice.
    "You must be," said the Cat, "or you wouldn't have come here."
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    ^^Hmmm... stick to the porn.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Elsewhere
    Quote Originally Posted by djmickyg
    What older programs?
    There's a lot of old programs that don't like Win2000/XP because of the NT base. Of course, they didn't like NT4.0 either for the same reason.
    How about the Wiki?
    Feb 2004
    Quote Originally Posted by DarquePervert
    atm im trying to install NFS2. but it has happened to me a number of times. and ive had no way of installing what i want to install
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    But I think I actually had NFS:IISE playing on my craptop with winXP.
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    You could try installing it under a compatability mode. Make a shortcut to the install file, right click on that shortcut and choose properties. Click on the Compatibility tab and check off run this program in compatibility mode for..., you can then choose 95 or 98/ME, try both, somtimes if one doesn't work the other will. Hope that helps.
    BTW, what is this doing in general hardware discussion?
    Constant Bitrate blackbravo's Avatar
    Nov 2004
    Southampton, UK
    I had a very simiilar problem. it turned out ot be a problem with XP someone i know sent me a fix. But i`ve just had to format my PC so i dont have the file anymore.
    But it was on MS`s website, they should b able to help u.
    Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
    Acquired a Toshiba Satelite 4000CDT
    HDD`s ****ed new one on way! 30gb Toshiba.
    Jan 2005
    try placing the contents of this zipfile over the one that is at the location listed it has worked for several of my clients
    Attached Files Attached Files
    Feb 2004
    blackbravo : i did a search for it and found it.. it works now thanks..
    yonu; i didnt look here in time to see ur file.. but thanks anyways
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
