Results 1 to 8 of 8
Thread: usb wifi with detachable ant?
    Aug 2002
    Eau Claire, Wi
    since my system is installed in my glovebox there really isnt room for a pci card. I currently have a dlink 802.11b usb adapter. I would like to get somehing that has a bit better range and upgrade to g. Does anyone know of a usb wifi adapter that gets extreemely good range or has the ability to attach an external antenna?
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Search for Linksys mods. There is one around on how to add a connector to a USB adapter. Its pretty simple from what I remember.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    I originally had a PCI with an external antenna and it worked well
    Ive since migrated to a case which doesnt allow PCI cards so I moving to USB
    Im going to just put a USB wifi "stick" type device under the plastic of the front dash
    Ive read reviews on the IOGear GWU513 unit and it apparently has a good internal antenna and you cant beat the size
    Constant Bitrate csnowman00's Avatar
    Feb 2005
    Wilkes-Barre, PA
    do the usb adapters come close to the ranges of pci cards with external antennas?
    Current Progress:
    Final Assembly
    Ramline P3 PC
    10.4 inch Touchscreen
    Windows XP Embedded
    Road Runner
    Electrical Engineer / Mobile DJ
    Constant Bitrate bridqer's Avatar
    Nov 2003
    The better wifi devices, wether pci usb or rj-45, are adapters with pcmcia cards in them. Most of the integrated wlan chip devices are not as good. I have read that with the linksys wet11 ver1 bridge you can change out the card with higher power cards to increase the range. Definitly get some thing with an external antenna like the orinoco pci adapter.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    i got a buffalo USB wifi and it lets me use a antenna with a MC connector on it, i have the antenna on the roof and the dongle buried in my dash. works great!
    If you want ill get the model.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    next - wifi
    Low Bitrate Alex121's Avatar
    Feb 2005
    Gold Coast, Australia
    ah orry what was the model?
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. 802.11G WiFi Adapter -- USB, Cardbus, CF, or RJ45 Ethernet?
    By Bailey in forum Wireless Communications
    Last Post: 01-22-2005, 11:33 AM
  3. What USB Wifi to buy?(UK)
    By vintageb3 in forum Wireless Communications
    Last Post: 01-17-2005, 06:02 PM
  4. wifi usb solution
    By turbochris in forum Wireless Communications
    Last Post: 07-22-2004, 10:59 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
