Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: vga extension cable
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    vga extension cable
    hi to all, i am planning to move my carputer from under my seat to the car's trunk. i have a xenarc 700 tsv touch screen monitor, i am wondering is it ok to just use a vga extension cable to run my vga to the trunk, also i am planning to use a usb extension cable for the touchscreen. will this have any effect with the quality of the signal compared to buying the 5meter xenarc vga cable? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Mar 2005
    as long as you dont use more then a total of 12.6 ft of cable you should be ok. More then that and video will degrade drastically. So if you have a 6 ft cable on the back of the touch screen you will only be able to use 1 extention cable.
    Feb 2005
    ca
    ok thanks for the tip
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Wait a sec.. Can someone verify this? I know alot us have installs in the trunk. I strongly doubt i could make it to my trunk with 12 feet and i have a midsize sedan. I was planning on getting at least a 15 foot. Anyone else have extensions longer than 12 feet?
    Super Moderator xBrady's Avatar
    USA
    I am using 3, 6 foot extensions for both the VGA and USB, not a single problem.
    Installed.
    -GPSSecure- - GPS Tracking
    Aug 2003
    Quote Originally Posted by xBrady
    I had a 20 footer vga with no probs.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    I am using a 25ft extension with no problems
    http://www.gocables.com/Merchant2/me...t_Code=GC71812
    Feb 2005
    ca
    thanks for the tip again, yeh i did not buy yet coz i was wondering if the 6ft would actually reach my trunk, its a good thing that going longer than 12 feet is no problem.
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Woodbridge, VA
    Blog Entries
    32
    Thanks for clarifying.. i'll get the one i was lookin for
    Tainted Love Cris's Avatar
    Romania
    Make sure it's properly screened, other wise it will cause interference.
  1. Best VGA to RCA cable or inverter?
    By brizzle in forum Input Devices
    Last Post: 02-10-2005, 01:30 PM
  2. Is this VGA extension cable overkill?
    By eatyummypuppies in forum LCD/Display
    Last Post: 09-15-2004, 08:36 PM
  3. Replies: 3
    Last Post: 09-03-2004, 08:07 PM
  4. Fuzzy output using long VGA cable...
    By sq_geek in forum LCD/Display
    Last Post: 06-11-2004, 08:37 AM
  5. 9pin extension cable in uk ???
    By eazyrog in forum LCD/Display
    Last Post: 05-13-2004, 03:11 PM
