Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Laptop vs desktop
  1. #11
    Mar 2005
    sounds like the remote start is still the biggest problem for the laptop caruter.
    I saw some replies on people rewired the laptop power/standby button to the front of the car, while this served the purpose it also removed one of the biggest advantage of the laptop carputer. That is you can't pop the laptop out and take it with you anymore.
    I think the best solution is "wake on ring". when the car starts up, wired it so it will send the magic wake up packet to the laptop and turn on the machine. I saw someone claim that s/he had done this. I need to find out more. If you know how to do this, please share. thanks
    "wake on lan" is a no go, since it requires an ip/mac address
    "wake on mouse click" sounds like a good idea. All you'll have to do is touch the lilliput touchscreen to emulate the mouse click. However i have never seem this option in any bios and couldn't really find anything online either.
    "wake on keyboard" is another option. However, this requires you to have to keyboard available at all times.
    My laptop carputer supports wake on ring. i'm going to find out more and see if i can fashion something that simulates the "magic ring"
  2. #12
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    I could, but it was ugly, mine had quick disconect plugs on it
    - you had 2 wires with plugs on the end of them hanging
    out of the laptop - You could if there is room use a mini phono
    plug inside the laptop - or maby use the MIC plug and rewire it,
    but yes there is a way
  3. #13
    Mar 2005
  4. #14
    Mar 2005
    Quote Originally Posted by will1384
    Yeah, i know you could make it so it's detachable from the extension wire, but it would be ugly. i rather people think "gee, that kind of geek brings a laptop to starbucks?" than "gee, don't get too close, I might get electrocuted by the 2 lose wires sticked out of that laptop."
    it seems to me getting a dockstation and rewire the power on the dockstation might be the way to go. This way, you can have the best of both world.
  5. #15
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    I opened my laptop up, soldered 2 wires to the power button and snaked them out the
    back. Then I just put a plug on it to make it easy to rip out of the SUV if I need too.
    I removed the screen from my laptop and sold it on ebay, so I'll never use it alone so
    the wires are fine.
    If you are using a laptop you want to take out and continue to use, a member back in the
    day used a small r/c plug that he made fit in the side of the laptop and looked very clean.
    I just did another laptop yesterday for a friend, and I ran the wires out of the docking
    station port area, that has a cover so the wires can be hidden when removed.
    As far as the remote start, you have many options... I made my own timer circuit so
    it turns on and off with the key and has delays built in for startup and shutdown.
    When we did my friends install, he just wanted to be able to control it by a button
    on his dash, and that works out real well also.. you just have to make sure
    you protect the wires coming off the switch with a relay so you don't fry the
    laptop... (there is +5v on them).
    I still think a laptop solution is cheaper and easier than a desktop imho
    and yea docking station that you mod keeps the laptop virgin too...
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
  6. #16
    Jul 2004
    ^^^I would like to know how you build your timer circuit. Though I am not looking to wire it to the power switch. Eventhough, I have a docking station.
  7. #17
    Mar 2005
    Ohio
    wei2cool........
    The direct wire to the battery?
    I simply got an extender for the post on my battery, that had a spot that I could attach another smaller wire. hardest part then was drilling through the firewall, to create a path for the wire. Wouldve used an existing one, but too new, there wasnt one. Cut the plug off the triple head socket, and wire directly to wire from battery.
    Was pretty easy in my full sized pickup. probably a pain in a small car.
  8. #18
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by Squid
    Thats what i did. The Dell docking stations (at least for the inspiron) has a little screw panel in the back that opens up to show a PCB with the momentary switch. Soldering just takes stady hands and a pair of reading glasses!
    Plus the laptop stays unopened.
    I just ran two thin (18 or 20 AWG) wire to the trunk and had a push button switch in my ashtray.
  1. FS- 1 Laptop HD and 1 Desktop HD
    By falconey in forum Classified Archive
    Last Post: 10-15-2004, 06:36 PM
  2. Need Desktop HD to laptop Mobo Connector
    By Joe_Collectible in forum General Hardware Discussion
    Last Post: 09-26-2004, 09:38 PM
  3. Laptop parts in a desktop
    By daguju1der in forum General Hardware Discussion
    Last Post: 07-25-2004, 03:36 PM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
  5. laptop hdd in desktop
    By slackingoff in forum General Hardware Discussion
    Last Post: 08-11-2003, 10:22 AM
