Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 61
Thread: Hard drive shock / vibration thoughts
  1. #11
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    d'oh! I see it now. Are you using bungee cords to mount it like that?
  2. #12
    Low Bitrate S11D336B's Avatar
    Feb 2005
    Florida
    I think some of the specs that are given in this thread are a bit bogus. Here are the specs for an IBM 120GB 7200RPM DESKSTAR.
    Environmental Parameters
    Min Operating Temperature : 5 °C
    Max Operating Temperature : 55 °C
    Humidity Range Operating : 8 - 90%
    Shock Tolerance : 55 g @ 2ms half-sine pulse (operating) / 350 g @ 2ms half-sine pulse (non-operating)
    Vibration Tolerance : 0.67 g @ RMS (random) (operating) / 1.04 g @ RMS (random) (non-operating)
    Sound Emission : 31 dB
    http://www.memorysuppliers.com/ibm1272desid.html
    So, 55g OPERATING 350g NON OPERATING for shock.
    So, data shows orientation of the hard drive may not be a significant factor as it can take 60Gs of shock without failure presumably in any orientation. Getting a hard drive to experience 60Gs of shock when mounted to a 2500 pound car is a feat. The accident that caused Princess Diana's death was 70Gs. So, I eat my words, happy? However, it is only because of the weight of the car that the force was 70Gs. A hard drive which weighs say, one pound, dropped from one foot would experience far more force than this. Thus anchoring the hard drive to the car firmly is imperative.
    Vibration tolerance is only 0.67g OPERATING and 1.04g NON OPERATING.
    This shows that vibration IS a significant factor. Cases where people are mounting their hard drives rigidly to their car without failure may not be experiencing much vibration. However, this is definitely something the hard drives are prone to failure from.
    So like I said before, mount your hard drives in a mount that is rigid enough to take on the mass of the car, but not so rigid that it transfers vibration. This gives the hard drive the greatest possible chance of survival in any condition.
    ________________________________________________
    Worklog
    K7VTA3
    1500+ Athlon 4 Mobile
    510mb PC3200 DDR
    ATI Radeon 7000 64mb
    [||||||||||] 95% Complete
    RentATechnow.com
  3. #13
    Mar 2005
    Ohio
    This is not exactly what you are looking for, but It shows a dampening concept that I have found to work quite well. I use it in my motorhome, which is verry vibration prone going down the road.
    I think with some creativity, this concept could be adapted for harddrive suspension.
    Just need to build an appropriate frame work
  4. #14
    Feb 2005
    Wow, oldschool. But if it works..!
  5. #15
    Low Bitrate crazymadbastard's Avatar
    Jan 2005
    Connecticut
    I say buy an 1:10 scale rc car and mount the hard drive into the car. That way you can have 2 suspensions, your car's and the rc vehicle's. Crazy, but it should work .think about it.
    Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
  6. #16
    Feb 2005
    Florida
    Quote Originally Posted by crazymadbastard
    I agree, the shock, spring combination seems very adventagous to preventing vibration and shock. However, this would only dampen shock and vibration in the horizontal plane. . .
    Worklog
    K7VTA3
    510mb PC3200 DDR
    RentATechnow.com
  7. #17
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    dont they sell vibration dampening gel that would be ideal for this?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  8. #18
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Here is what I did.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  9. #19
    Oct 2004
    Its kinda hard to tell but i made a cantilever support. The weight of the hard drive provided the cushion along with the elasticity of the bracket. I mounted the bracket to the case with rubber washers on both sides of the bolts.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  10. #20
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    My MR2 has next to no suspension and British roads are riddled with potholes, I drive over a bridge on the motorway that has a nasty dip in it five days a week, my drive is rigid mounted and has worked faultlessly, but I will eventually mount it in a cage using R/C suspension (as previously mentioned), angled to cover all axis, this is a similar setup to a lot of CD changers and should stop most of the vibration and jarring from reaching the drive.
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 01:53 PM
  2. Can I boot from a removable USB Hard Drive?
    By ayclens in forum General Hardware Discussion
    Last Post: 11-12-2004, 03:43 PM
  3. Problems with EBAy kiosk and hard drive?
    By davcd3 in forum General Hardware Discussion
    Last Post: 08-12-2004, 05:08 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
