Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 61
Thread: Hard drive shock / vibration thoughts
  1. #21
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    I've done a rough of the idea i have.
    The hard drive will be suspended in a cage between eight long throw R/C spring/damper assemblies set on their softest setting, they will be compressed to half their travel so that the Drive has full movement in all directions, this should be in theory easy to build and highly effective, if someone has a better idea, I am open to suggestions/riddicule.
  2. #22
    Low Bitrate crazymadbastard's Avatar
    Jan 2005
    Connecticut
    the hell with all this *****, I am gonna just TIG weld the sucker onto my tranny, ur all a bunch of pansies!
    Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
  3. #23
    Feb 2005
    Bristol UK
    It's your drives funeral mate, let me know how you get on
  4. #24
    Jan 2005
    Connecticut
    Quote Originally Posted by S11D336B
    I agree, the shock, spring combination seems very adventagous to preventing vibration and shock. However, this would only dampen shock and vibration in the horizontal plane. . .
    You still have the wheels on the rc car right? That should sufice, if you wreck your drive using this, you probably have had a very bad accident (because of the on- screen pr0n distracting you )and have much more imporant things to worry about,( buttoning up ur shorts before the ambulance gets there) etc.
  5. #25
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Actually, if you mount the springs at a 45° it would dappen in all directions. Thats why if you look at the rear of a truck you will ususally see them at somewhat of an angle.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  6. #26
    Mar 2005
    Ohio
    OK, so how about this strategy. Since quite a few have claimed no problems with many miles, then I will simply bolt the sucker to the floor, and worry about it when/if the sucker goes bad. With harddrive space so cheap these days, surely everyone has backed up everything that matters on these car hard drives anyway right??
  7. #27
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by mrshelf
    Just a little reading on this topic will find my experiance in this realm.... more than one car wreck with a 3.5" drive playing music.... Just fine... the drive is so much more durable than the driver it will not matter. Suspension of the drive may cause more trouble and will certainly be more time to install.
    TruckinMP3
    Read the FAQ!
  8. #28
    Apr 2005
    hell, why not just put a wireless network card in your car and upload all your files to your house every once in a while? I think it would take care of any data loss worries... and if your hard drive goes out quickly, send it in on warranty (tee-hee) and then mount the new on in a new way... if it wears out again, get your $$ back and buy a different brand
  9. #29
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Before I puke from reading another hdd shock thread, I'd like to say that in the 5 +/- years I've been here, I've never heard of anyone loosing a drive to shock. The things are built so cheaply these days, you'll be lucky to get 6mos out of them reguardless of the conditions they're placed in!!!!
    Off rant, does anyone have one of these thingamajigs - http://www.cockpit-solutions.com/
    Better yet, thinking back to an old highschool experiment, I think one could rig up a G-Meter from a weight, a spring, and a ruler...
    It would be interesting to see how many G's the average pothole puts on the frame of your car!
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  10. #30
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    S11D336B - less bull**** and more data. Your theories sound fine. You've articulated the problem eloquently but you have NO DATA to prove or disprove them.
    How about some vibration and shock tests for different drive positions and shock absorbing techniques on a calibrated vibration table, configured identically, running the same software, performing the same access routines? Until then, it's all anecdotal evidence.
    Here's my anecdote: 3.5" Fujitsu BOLTED to a piece of wood that's screwed to my rear shelf. 8 months, no failures. So there.
    Want to:
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 01:53 PM
  2. Can I boot from a removable USB Hard Drive?
    By ayclens in forum General Hardware Discussion
    Last Post: 11-12-2004, 03:43 PM
  3. Problems with EBAy kiosk and hard drive?
    By davcd3 in forum General Hardware Discussion
    Last Post: 08-12-2004, 05:08 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
