Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 61
Thread: Hard drive shock / vibration thoughts
  1. #51
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by alienjj
    When I was building my carputer, I kept thinking of ways of to protect my hard drive and this is what I came up with.
    To fit in my van, I decided to mount the hard drive vertically. So I figured out a way to mount it using long little screws that screws attached to plexiglass, then I figured why not have them move so if it hit a bump it could move like a shock absorber. So i went to home depot and looked for some small pieces of rubber, and i found them in the plumbing department they compress down and then pop back up, they are about the size of finger in circumferance, and about a centimeter tall. There was some extra space when i put them in, so i filled it will small squares of cardboard stacked on top of each other till it was tight. Now it moves just enough to absorb shock and vibration and is strong enough that it doesnt just move around all the time.
    So, basically this creates a shock absorber, just like in a car.
    That is great, you have added additional motion and potentially a cause for failure to your set up.... Excellent.
    TruckinMP3
    Read the FAQ!
  2. #52
    Raw Wave justintime's Avatar
    Apr 2005
    I would be much more worried about temperature changes than vibration. I would bet that a HD in a car is much more prone to fail because you parked it at 20 degrees Farenheit overnight in winter (every night, all winter), and then heated the hell out of it with your car heater and self-emmited heat.
  3. #53
    Jun 2002
    Colorado
    Quote Originally Posted by justintime
    Gods... no one reads anymore .... this also has been covered. Some drives with Fluid Dynamic Bearings (FDB) have trouble in low temps.... many have no trouble at all.
    TruckinMP3
    Read the FAQ!
  4. #54
    Newbie mxl4729's Avatar
    Dec 2004
    westwood
    Not that I am going to change anyone's mind here but I am an engineer for Veeco we make the ion deposition machines that make hard drives. One of the process that goes into making a hard drive is coating the platters with a plasma of carbon atoms that once it has harden is almost as hard as diamonds and the structure closely resembles the molecular structure of diamonds. this is the reason you hard drive does not fail when u go over bumps because the heads have no way of scratching the surface of a platter that hard
  5. #55
    Nov 2003
    Florida
    Quote Originally Posted by TruckinMP3
    Actually it moves very little, like with just normal driving it doesn't move, but i've watched when hitting a pot hole and the hole car jolts down really fast the hard drive will move but softly, instead of a jolt, and then return to its original position, and not bounce around like if you had it hanging from bungie cords or something.
    -=Chevy CarPC=-
    ETA: When i get more time
    -Custom Fiberglass Case
    -Epia M-10000 Nehemiah 1Ghz
    -Sony CDRW-DVD Drive
    -Seagate 120mb Hardrive
    -Opus 90w Power Supply
    -Lilliput 7" LCD
  6. #56
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    Thumbs up
    Many people have mentioned mounting the hard drive on springs like a car and many people have mentioned how detrimental the continual movement from this setup can be. But why has no one ever combined the two ideas. If cars only had springs they'd bounce like a b!@#$ just like your hard drive will if it's only on springs. This is why cars have shock absorbers, to remove any remaining bounce the spings might have after being compressed and then released. If the drive were on springs and had shocks you'd get a more ideal setup; the drive would no longer bounce ten times for every one time the car bounced. Most definately overkill, but just a thought.
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
  7. #57
    Jun 2002
    Colorado
    Quote Originally Posted by unixxx
    Actually that has been covered as well. Damping systems is what you are refering to.
    If you are interested in expensive solutions to problems that do not exist, go ahead and build one.
    TruckinMP3
    Read the FAQ!
  8. #58
    Elsewhere
    (Sorry for the crappy photos!)
    I used the rubber feet from the Shuttle case I'm using. The hard drive is bolted right to the lid of the Shuttle case, which will be mounted upside-down under the dash (making the drive parallel to the ground).
    I've got to agree with the consensus that vibration and shock on the hard drive is a really minimal issue.
    I'm wondering how many people who have had HDDs die in their cars would have had the same HDD die in a desktop. We'll likely never know, but it's interesting speculation.
    How about the Wiki?
  9. #59
    Sep 2005
    CA, USA
    Wink
    Hence, "Most definately overkill, but just a thought." Even if there were a problem it would be cheaper to just keep buying new drives on eBay.
  10. #60
    Jan 2004
    Norwich, CT
    Yeh, def not cheaper when it's a 500 GB hard drive
    Looking to buy or sell a home in Southeastern CT?
    Click here: timfrederick.prudentialct.com
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 01:53 PM
  2. Can I boot from a removable USB Hard Drive?
    By ayclens in forum General Hardware Discussion
    Last Post: 11-12-2004, 03:43 PM
  3. Problems with EBAy kiosk and hard drive?
    By davcd3 in forum General Hardware Discussion
    Last Post: 08-12-2004, 05:08 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
