Page 1 of 7 1234567 LastLast
Results 1 to 10 of 61
Thread: Hard drive shock / vibration thoughts
    Low Bitrate S11D336B's Avatar
    Feb 2005
    Florida
    The whole issue of hard drive failure must be broken down into the facts. Working with cars and airplanes with a few years has allowed me to gain some kind of knowledge in this field. There are two components we should be talking about when trying to protect a hard drive in a car. These are shock (half sine wave) and vibration (full sine wave). Shock occurs when a hard drive encounters acceleration and a sudden stop. Vibration is a continuous acceleration and deceleration oscillating from one direction to the other. To prevent damage from shock, increasing the mass of the hard drive by mounting it directly to the chassis of the car is a great idea. However, this does not help the vibration problem and will probably worsen it. So, what is really needed is a firm mount that accelerates with the chassis of the car when it encounters shock, but not so firm that it transmits the vibration inherent in any car to the hard drive. Some believe that going over pot holes only causes shock to occur. This is not true. Shock is the most significant force resulting from this. However, a noticeable amount of vibration can result. Listen to your car the next time it goes over a pothole. The clunk clunk sound you hear is shock. The rattle rattle sound you hear is vibration.
    As far as the orientation of the hard drive is concerned. There are pros and cons to each. Mounting vertically keeps the heads from smashing into the platters, but may allow the heads to smash into the walls of the hard drive enclosure and read incorrect data. Gravity isn’t a factor at all in this because most hard drives are designed to be mounted either horizontally or vertically. Mounting the hard drive horizontally makes the head prone to smashing into the platter upon any kind of shock. However, this does keep the head from being moved by shock.
    Vibration affects hard drives the same regardless of orientation. The direction of vibration varies significantly from car to car and situation to situation. This is caused by different speeds, cars, and road conditions. Because of this, only shock can be considered in the orientation argument, because it is the only constant factor with regard to direction.
    So, excessive shock may cause read errors when mounted vertically causing a system crash. You restart the computer and everything is ok
    But mounting horizontally will crash the hard drive. You try to restart the computer and it freezes / gives you errors and you have to buy a new hard drive.
    Now that we know exactly what we are trying to dampen, maybe someone can come up with a design that does this best. IMHO a silicon or rubber dampener seems to be the best solution. Like the one found in the link below I use visco elastic foam (memory foam) on mine. It works well, but I do have a heat problem. This sort of deisgn would allow for better heat dissipation.
    Hard suspension test.
    A rigid design that allows the hard drive to take on the mass of the car when experiencing shock, but not so rigid that it transfers too much vibration.
    Hopefully I inspired someone somehow by writing this. . .
    ________________________________________________
    Worklog
    K7VTA3
    1500+ Athlon 4 Mobile
    510mb PC3200 DDR
    ATI Radeon 7000 64mb
    [||||||||||] 95% Complete
    RentATechnow.com
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    I've had a maxtor 80gig hard drive sitting in a case tied down to the floor of the back of my wagon for more than a year and i haven't had a skip yet.. not one.. am i lucky? it's a normal 3.5 hard drive..
    i also have sports suspension lowered over 1" all around so this will make the ride even bumpier.. In addtion I have 18" rims..
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    130,000+ miles in a 4x4 and no problems
    2001 S10 ZR2
    Chucks Skin - to old
    Dec 2004
    Wichita Falls, Texas
    5 months in a Shuttle SFF box Sitting right in front of the Subwoofer enclosure. Not a hiccup.
    I still think this whole platters crashing vibrations messing rotation with car direction is a bunch of myth hoopla.
    Oct 2004
    East Sussex, England
    Quote Originally Posted by koolaidkitten
    Agreed.
    There seems to be no pattern between orientation and damage to harddrives. I think all of the self-professed harddrive experts should shut the f**k up.
    The only people that actually know the answers to these questions are the engineers that design and build the harddrives.
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Chuck: How are your drives mounted - vertically or horizontally? (not immediately clear from the pic)
    Mar 2004
    Shock ratings are 200-400 Gs for normal hard drives and 800-1200 Gs for 2.5" hard drives.
    Is there any evidence that this isn't sufficient for normal (and even abnormal) operation in a vehicle?
    Oct 2004
    Quote Originally Posted by ktritz
    Aren't those ratings for a powered down drive though?
    I thought a powered up drives ratings were usually below 200.
    SOS
    SOS is offline
    Jan 2005
    My 3.5" is mounted vertically in a piece for hard-foam, in which I have cut a hole just a bit smaller than the disk (so that it will sit very tight), but I have only lowered it approx half into the foam, so that it will not overheat.
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by rubicon
    It is on a 45-degree angle and the front of the drive is facing to the right with the ribbon cable coming out of the rear left.
    2001 S10 ZR2
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 01:53 PM
  2. Can I boot from a removable USB Hard Drive?
    By ayclens in forum General Hardware Discussion
    Last Post: 11-12-2004, 03:43 PM
  3. Problems with EBAy kiosk and hard drive?
    By davcd3 in forum General Hardware Discussion
    Last Post: 08-12-2004, 05:08 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  5. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
