Results 1 to 2 of 2
Thread: Anyone have SPDIF output working well on an EPIA M-II?
    Mar 2005
    Question Anyone have SPDIF output working well on an EPIA M-II?
    I've read all the threads on activating the SPDIF output on the EPIA M-II and done it all (changed jumper, activated SPDIF in Volume Control, Advanced, etc.). Nothing is coming out of the SPDIF jack on the M-II (and I verified that I get composite video when the jumper is in the 1-2 position, so in theory 3-4 is correct).
    If you've got it working well (i.e., you actually use it, as opposed to having knowledge about how it's supposed to work), can you please post what software you're using? PowerDVD? AC3Filter? ZoomPlayer? I'm hoping this will help me figure out what's missing or wrong.
    Thanks in advance.
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    In my dakota I use spdif on my mii every day. I have mii10000 and a pg r5.1mt amp with a pcm cable(75 ohm i think). I use frodoplayer t3 and powerdvd 5 codec. To enable set the jumper to 3-4, open the volume control panel(double click the systray volume icon). Enable spdif in the advanced section(if it is not there install the adio drivers for the mii).
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
  1. 6 channel output from EPIA MII
    By ajaswa in forum Newbie
    Last Post: 03-16-2004, 05:29 AM
  2. Replies: 3
    Last Post: 02-01-2004, 02:02 PM
  3. Epia M working with a Sproggy like PS
    By Trottingwolf in forum Power Supplies
    Last Post: 08-04-2003, 04:01 AM
  4. EPIA M and Datalux not working
    By Typhoon747 in forum LCD/Display
    Last Post: 12-10-2002, 08:39 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
