Results 1 to 10 of 12
Thread: too stupid to try?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    too stupid to try?
    Well, being that i really don't need this old 500 mhz laptop anymore....(being as i am selling it).........if it doesnt sell within the week I plan on trying to hook it up straight to the cars AC line. I will put a small inline fuse so the thing cant get more then 5 amps or so. The reason I am even concidering this is that the power adapter i use for it says it outputs 10-16v, and 2.2-3.2 amps. Will this thing definatly explode? cause if so, i might think twice.....of course if i do attempt it......i will take a few precassions......wire it up to a fused distrobution block and not have the thing sitting in my car while its on.....and use pretty heavy grade wire.....i'm thinking 8guage as i still have some laying around.
    oh, one more thing, i promise not to attempt this before the end of the week (and if someone buys it first, im not gonna do this)
    Any thoughts?
    PC Components:
    My work log
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by Peoples
    Any thoughts?
    Take pictures
    Low Bitrate code-'s Avatar
    May 2004
    Haugsund, Norway
    I've done this with an older laptop before. It still works
    1984 BMW 323i (E30)
    [==========] 90%
    EPIA MII10000
    256MB RAM
    40GB 2,5" HD
    Lilliput 7" TS
    Hacked Travla C134
    Haicom CF GPS
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    what does the bottom of the laptop say - its not amps, its volts
    you need to worry about - it will only draw the amps it needs
    AMPs is like a volume of water
    Volts is like water pressure or how fast the water flow is
    Most laptops use 16v to 20v now days with most 18v-19v
    I have a old 486 laptop that will run from 12v with no power
    adapter at all
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    whoa...is it 120v or 240v ac?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Maryland
    hmm, odd, i didnt even think of checking that....the bottom of the laptop says 16v....you think it will work?
    PC Components:
    My work log
    Dec 2004
    Maryland
    Quote Originally Posted by scott_fx
    by ac, i should have said acc....meaning accessory
    PC Components:
    My work log
    Dec 2004
    Los Angeles Ca
    i figured as much... just giving you a hard time
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2002
    Actually, your alternator outputs AC (alternating current), it's just retified (made into DC by use of diodes) before your battery.
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    I'd say your hit or miss there. My general opinion is that voltage in the car is not clean enough to power the laptop without causing freezing and potentialy damaging it. There is a reason that most ac/dc converters for laptops are expensive, they do quite a bit of filtering.
  1. Rage against some stupid things
    By kraft in forum Off Topic
    Last Post: 11-07-2004, 05:29 PM
  2. Did I do something very stupid ?
    By Nokia6600 in forum Power Supplies
    Last Post: 03-02-2004, 11:54 AM
  3. stupid question
    By Cliff in forum MediaCar
    Last Post: 11-19-2003, 04:10 PM
  4. The bad news is PEOPLE ARE STUPID!!
    By cproaudio in forum General MP3Car Discussion
    Last Post: 08-07-2003, 01:25 AM
  5. Hahaha Stupid Theves!
    By orangewhip in forum General MP3Car Discussion
    Last Post: 05-11-2002, 04:07 AM
