Results 1 to 10 of 12
Thread: Operating system not found... help!!
    Dec 2004
    Well, sometimes i leave my laptop on all night and the other morning i woke up and it had some error on it so i didn't read it and just turned it off. When i went to turn it back on i couldn't get it to work... It would start to load (screen with press F2 for ...) then it would come to a black screen with white writting that said 'Operating system not found' I kept trying and trying and it would just go to that screen. I finally decided to press F2 to check into it and it said under the title hard drive 'none' So i thought maybe i have a crash. well eventually i exited that screen and it just booted up for me. I turned it off, went to bed, turn it back on and it said the same thing 'operating system not found' i played with it again and finally got it to load. Is my hard drive about to crash?? Is it a virus or something?(i did a virus scan and got nothing) Should i buy another hard drive? should i start saving all my important stuff to cd's? Any suggestions and comments are welcomed.... thanks.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Harddrive may be on the way out. Purchase new one and ghost contents over to it.
    or it could be just the drive getting to hot and playing up for a while.
    I've had that with my work Dell laptop when I've forgotten to turn it off. the drive overheats and then won't play ball until it's left to call down for a while.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    it might be your mbr is currupt
    try booting off of your xp cd and going into the recovery console
    type the following commands
    fixmbr c:
    fixboot c:
    bootcfg /rebuild
    warning i've read that following the directions above had screwed up a few people's mbrs, i've never had this problem however.
    PC Components:
    My work log
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    Yeah, fix mbr in the recovery console, works every time! Ive had this prob on several friends machines and it worked. Never hurt either. For a list of those commands in dos recovery console type help.
    Dec 2004
    Quote Originally Posted by Peoples
    fixmbr c:
    fixboot c:
    bootcfg /rebuild
    Will i loose anything? What kinda problems?
    Dec 2004
    Quote Originally Posted by Enforcer
    How do you 'ghost' it over?
    Dec 2004
    Maryland
    you should loose anything, people have said that its destroyed their master boot record, but.....if people are using fixmbr.....usually its because there is something wrong with their mbr in the first place
    PC Components:
    My work log
    Dec 2004
    Maryland
    ghost is an image application made by norton or symmantec....you have to find an app that allows you to copy images to 'ghost' a hdd
    PC Components:
    My work log
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jol102001
    as peoples said it's an application that allows you to copy a drive like for like.
    Mar 2005
    Sarasota, FL
    eiither youve lost it, or you havent. Fix Mbr is not going to corrupt anything you could still pull out of there. It's worth a try, already.
  1. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-17-2004, 12:38 AM
  2. Carpc Operating System?
    By chuckctv in forum Software & Software Development
    Last Post: 09-13-2004, 10:47 PM
  3. my planned system
    By link138 in forum General MP3Car Discussion
    Last Post: 08-13-2004, 12:58 AM
  4. Line converter with a Delco Bose system?
    By JGeek in forum Newbie
    Last Post: 03-27-2004, 02:46 AM
  5. Do I have HU or not? -- Factory Audio system
    By helloman in forum General Hardware Discussion
    Last Post: 03-06-2001, 04:11 AM
