Results 1 to 4 of 4
Thread: Via Epia M10000
    Rik
    Rik is offline
    Newbie Rik's Avatar
    Jan 2005
    The Netherlands
    Via Epia M10000
    I've got an Epia M10000 mainboard but it won't power up when a device is connected to one of the USB ports. Is doesn't respond when I press the power button. Only when I remove all the usb devices it will power up.
    Anyone who knows this problem?
    Rik
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    look at the top of all of the capacitor. if one of them is raised in the middle you've got a bad cap. there is are several threads on here stating that all of the EPIA are prone to having the caps go bad eventually, and suffering from symptoms similar to these. Take a picture of a closeup of the board and post it.
    PC Components:
    My work log
    Dec 2004
    Maryland
    Epia Motherboard GCS Capacitor Issues
    the bad caps should say GSC on them
    PC Components:
    My work log
    Rik
    Rik is offline
    Newbie Rik's Avatar
    Jan 2005
    The Netherlands
    Problem solved
    My problem is solved.
    I tried another power supply. Now the system powers up perfectly. Also with the USB devices connected...
    BTW... my Mobo has the new 'nichi.... something' capacitors and they looked fine.
    Thanks!
  1. Replies: 24
    Last Post: 02-19-2008, 02:03 AM
  2. Any tips for Gentoo on Epia M10000?
    By rubicon in forum Linux
    Last Post: 02-16-2005, 09:58 PM
  3. WTS: Opus 90w, EPIA M10000 (new refurb), Lilliput 8" screen
    By therussman2002 in forum Classified Archive
    Last Post: 01-12-2005, 01:01 AM
  4. FS: EPIA M10000 Mobo & 512Mb PC133 SDRAM (Brand-New).
    By buildfromscratc in forum Classified Archive
    Last Post: 09-20-2004, 09:32 AM
  5. Replies: 4
    Last Post: 07-06-2004, 10:52 PM
