Not necessarily 1 amp, both draw from the same source. You might try getting a powered hub and having the drive plugged into that (of course keeping the hub close to the system). If you're confortable with wiring electronics, you could could tap 5V off your system's power supply and running it down the USB cable (make sure you use diodes to prevent damage to the USB ports).2 usb ports would give you 1 amp, and i KNOW this drive doesn't pull over an amp....
LinkBack URL
About LinkBacks
