Results 1 to 10 of 10
Thread: Fan Timer
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    Exclamation Fan Timer
    before I get flamed for not I did under "Fan Timer" and if it's been discuss where???
    I'm almost done with my install...Currently running in the trunk:
    MicroATX MB
    P3 800
    512 PC133
    40G 2.5HD
    Opus 150 PS
    2 amp (2ch & 4ch)
    All in a custom box...One concern that I do have is over heating, since the pc is going in the trunk.
    Keep in mind that I live in miami...it gets hot during the summer. Is there anyway to have a timer for my fans...
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    What do you need a timer for? Most mobos have temperature controlled fans. i.e. if they get too hot, fan speed goes up.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by god_of_cpu
    I wanna run maybe 2 fan..1 blowing in the other out...
    I'm aware of controlled fans...but I would like something that would run for X amount of time after "shutdown" or maybe sometype of heat sensor that would trigger the fans on at a certain temp...
    Dec 2004
    Wichita Falls, Texas
    I have never thought of using one in the car, but in my house I do a lot of overclocking and need a fan that can run 60 seconds after the computer shuts down. Works rather well for me. You can even set it to run longer than that.
    http://www.frozencpu.com/bus-12.html
    Jan 2004
    Why? If your trunk becomes so hot as to exceed the temperature tolerances of the computer, something I doubt would happen, fans will do nothing since they will need cooler ambient air to actually work.
    Dec 2004
    It may or may not be worthwhile, but it doesn't hurt. When you shutdown the computer you are causing a sudden change in temperatures. Yeah the temps are fine and dandy when you are running it, but once you hit shutdown the fans stop. The cpu and other componets are still dissapating heat from when they were running..where does that heat go...it sits inside the case and lingers around and dissapates SLOWLY!
    Technically that really isn't good for your computer. Wether or not it does damage depends on the extremes of heat, such as in my case when you have your ram and CPU overvolted.
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    I have a easy circuit that I use for the fans in my amp rack of my car. I will see if I can find it soon, PM me if I forget.
    Feb 2005
    Miami, Florida. 305
    here are pics of the fans I wanna use...they are set to blow air out
    Feb 2005
    Miami, Florida. 305
    anyone with any ideas???
    Dec 2004
    *wonders if you saw his post earlier with his idea*
  1. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
  2. Fan problems on my carpc
    By JohnChimpo in forum General Hardware Discussion
    Last Post: 12-10-2004, 09:25 AM
  3. LED Fan
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 11-11-2004, 04:46 AM
  4. Do you need a very compact graphic fan controller?
    By more mods in forum LCD/Display
    Last Post: 09-24-2004, 07:17 AM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
