Results 1 to 4 of 4
Thread: usb-ide help please
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    usb-ide help please
    trying to power a now-external-internal dvd rom/dvdrw whatever i get to buy
    looking for easiest solution... i figure i have to give external power and am running a molex to the front... the molex will split (5v to a usb port and 12v back to a molex connector and to the dvd rom)... the two grounds will go to each respective device...
    since i have a usb port up front, i was going to plug the ide to usb into that...
    do i need one of those devices like this...
    or should i just get one with the ide-usb no power like this...
    [4Runna]
    next - wifi
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    If its external, you'll need
    1. a data connection, and
    2. a power connection
    To fulfill the first requirement w/USB 2.0, I recommend this (the non-powered version; they also have a powered version that uses a wall wart, but unless you're using an inverter, this is useless to you). Both adapters support 2.5" (notebook drives) and 3.5" (desktop drives) drive connectors.
    For power, you'll need a regulated +12v (and probably +5v...) for 3.5" drives, or +5v (I believe ATM) for a slimline (notebook) [C|DV]D drive or HDD (unsure of ampere/wattage requirements). Either tap the power in your computer for this, or come up w/another external supply. Oh, and you'll need ground, of course.
    EDIT: just looked at the links to eBay that you posted. Yah, thats basically what you'll get from the link(s) I provided. Get whatever's cheaper. Keep in mind the power requirements.
    Dec 2004
    NY
    so you really think i'll need both 12v and 5v for the one dvd drive?
    i'll just make a 10-12ft molex extension i'm thinking...
    off current topic but related to the power requirements, i have a usb hub that requires 5v, i can just tap into another molex and pull that to the front, or could i pull off that new molex extension i'm making... could i power 2 usb hubs off a 5v line?
    [4Runna]
    next - wifi
    Feb 2005
    Quote Originally Posted by nsmoller
    Not sure - but the molex (morex?) connector that comes out of a standard desktop PSU (and powers a 3.5" HDD or "desktop" [C|DV]D drive) supplies 4 wires: 2x GND (black), 1x +12v (yellow), and 1x +5v (red), if that helps.
    Sure, as long as you don't surpass the amperage limit of the power source.
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 11:50 AM
  2. Slim DVD & IDE to USB - DVD QLTY
    By ZimZimmer in forum Newbie
    Last Post: 01-19-2007, 05:37 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  4. DVD Rom IDE to USB, 25ft. would it work?
    By mattress in forum General Hardware Discussion
    Last Post: 02-04-2005, 03:03 PM
  5. Got my IDE > USB cable today.
    By d_sellers1 in forum Newbie
    Last Post: 10-05-2004, 12:40 PM
