Results 1 to 10 of 10
Thread: automatic audio switch
    Newbie ysutarko's Avatar
    Mar 2005
    Artesia, CA
    is NE1 know where to get an automatic audio switch??? or is there such thing ?? i want to use my USB FM Radio and my MP3 player to the Line-In
    Thank you kindly
    Mar 2005
    UK
    can you explain a bit better.
    FLAC mauri's Avatar
    Jan 2004
    If I read correctly you search one switch automatic drive with the Line In?
    Is one interesting question profit for the one that the D-Link DRU100 for instance uses and has to pilot an electric spar from car with the Line In to have a good receipt (as I have done me) however with manual switch
    Mauri
    Mar 2005
    Artesia, CA
    i have 3 plugs on my computer
    1. line-out/speakers
    2. line-in/auxilary
    3. mic
    i want to find out if there's an automatic audio switch if i want to plug my FM radio and my MP3 player to line-in ?? or can i just put a splitter for the line-in ??
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i know this is a little off topic...but why dont you just use your carputer's mp3 player???? lol isnt that what its all about?
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    This one needs a 12V trigger. Here is an automatic audio sensing one with a trip sensitivity control.
    Fabricator
    Mar 2005
    Artesia, CA
    EsKALad = well, my fiance has her own MP3 player and sometimes she has her own musics, that's why i'm looking for the audio switch
    Altimat = Thank you kindly, i'll check out the link you gave me
    FLAC mauri's Avatar
    Jan 2004
    Make one automatic switch for use with line out(speaker)and possible.
    My dubt is to use the Line IN...(is Input no Output)....for signal to use for make one "automatic switch" hardware.
    Mauri
    Mar 2005
    kansas
    If you have a carpc then more than likely it has usb ports somewhere on it. And i know they are usually not readily available. Thats why most people locate a hub somewhere that is. And i have personally never seen a mp3 player that doesnt have a usb connection on it. I would use a usb hub somewhere on or near the dash for external mp3 players and then line-in/auxillary could be used for your fm radio. And with the usb hub you have almost endless possibilities for connections. IE> digital camera/camcorder, external hard drive, thumb drive, bluetooth adapter, etc.
    Mar 2005
    Artesia, CA
    i tried using usb to play the mp3 player, it didn't work
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 05:25 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:51 AM
  4. Looking for a 2-way audio switch
    By Vadim in forum General Hardware Discussion
    Last Post: 07-15-2004, 07:34 PM
  5. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
