Results 1 to 3 of 3
Thread: Audio signal experts - please help (two line-level inputs wired in parallel)
    Feb 2005
    Question Audio signal experts - please help (two line-level inputs wired in parallel)
    Hi guys,
    I hope someone with more electrical expertise than I have can solve a problem I have. I've done extensive searching with no luck, but no answers yet. Here is my situation:
    I have a BMW e39 which is pre-wired for a cell phone. I have sucessfully installed a cell phone carkit and everything works as it should.
    There are two wires from the carkit that carry a line-level audio, which I've connected to two wires in the center console. The cell phone audio is now heard nicely from the car stereo speakers (somehow it is routed into the stereo amplifier).
    Here's the tricky part.... I have a portable GPS (Garmin Quest) which is a nifty little unit and has a small speaker that speaks turn-by-turn voice instructions. I have "tapped into" the two wires leading to the little speaker and hooked them up to where the cell phone carkit is installed.
    --> If I disconnect the cell phone carkit audio wires, and connect the GPS wires, I hear the nice GPS lady's voice coming out of the stereo speakers -and- the little speaker in the GPS itself (this is all good - sounds great!). But if I hook up both the cell phone carkit and the GPS (in parallel) then I only hear the cell phone.
    When they are both wired together it is like the GPS audio circuit shuts down - I don't even hear the GPS voice coming out of its own little speaker. Maybe there is some signal or voltage being carried by the cell phone carkit that feeds back into the GPS and causes this to happen?
    My only idea is possibly a diode - so that the GPS audio will only feed out into the car - but I have no idea where to start, what type or rating of diode to even try.
    Any ideas? It would be great to hear not only my cell phone but also my GPS through the stereo speakers!
    Thanks,
    Paul
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    You don't want to hook them up directly in parallel like that, nor do you want to use diodes. A couple resistors do the trick tho - check this page out for details: http://www.hut.fi/Misc/Electronics/c...s/linesum.html.
    Incidentally, this same topic is active in the newbie forum right now.
    Constant Bitrate csnowman00's Avatar
    Feb 2005
    Wilkes-Barre, PA
    i agree
    Current Progress:
    [▓▓▓▓▓▓▓---]80%
    Final Assembly
    Ramline P3 PC
    10.4 inch Touchscreen
    Windows XP Embedded
    Road Runner
    http://www.projektnepa.com
    Electrical Engineer / Mobile DJ
  1. Sound Card Line Level Output?
    By Krusher in forum Car Audio
    Last Post: 01-16-2007, 05:51 AM
  2. Amp turn on when audio signal is present
    By nrls2000 in forum Car Audio
    Last Post: 10-22-2004, 07:05 PM
  3. Wierd, wierd line level signal issues.
    By Hamster O Death in forum General Hardware Discussion
    Last Post: 03-21-2004, 02:29 AM
  4. directly wiring sound into stereo... anyone REALLY good?
    By ares in forum General Hardware Discussion
    Last Post: 12-30-2003, 05:37 PM
  5. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
