Results 1 to 9 of 9
Thread: blown videocard
    Nov 2004
    New York
    blown videocard
    Has anyone blown multiple videocards? The first videocard I blew was some old bulls*it card that was given to me, so when it blew, I didn't think anything of it. So I bought a GeForce 5500, and yesterday when I was driving, It appeared my system shutdown. When I parked, I looked in the back, and the pc was still running, but I noticed that my video card popped out of the PCI slot. I then powered down, plugged in the card, rebooted, and now I have no video at all. The interesting thing though, is that the fan attached to the card powers up.....Any ideas?
    Via epia M10000
    12.1" VGA touchscreen
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    Geforce 5500 Videocard
    Audigy NX USB sound card
    Wireless Keyboard & mouse
    Panasonic slim line -slot load
    w/ usb adapter
    IRMAN
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    Check that the pci slot is clean, you may have some dust in there that is shorting a contact.
    Mar 2002
    It could've fried by getting the wrong voltages to the wrong pins (dead shorts, etc.) when it poped out of the slot while on. Make sure your new card is secured in the slot.
    Nov 2004
    New York
    I noticed that both cards fit in the slot kind of snugly, although they can sway from side to side if pressure is applyed. While driving, I'm sure that turning, etc., causes this card to sway. How are you guys making sure that the card doesn't move while driving?
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    if the card is fitted correctly there's no way it could sway while turning.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Check for loose wires in you case that could hit the card.
    Also check your earthing on your case and your monitor etc. It is morel likey that the video card is just very sensitive to something like a spike than other components than blowing cos it's moving.
    Also check the VGA cable isnt breaking the connector on the board if it or the PC move.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i'd check the card in another PC make sure its blown.....maybe you fried the port....i've done that
    PC Components:
    My work log
    Mar 2004
    Bristol
    Quote Originally Posted by Peoples
    that is a good point, but dont try it in your uber expensive gaming rig. Test it on an old mobo if you can incase it is blown and damages the mobo.
    Nov 2004
    New York
    Thanx For The Replies!!
    I Will Test It Later Today!
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
  1. blown power supply?
    By crono35 in forum Power Supplies
    Last Post: 03-01-2005, 01:29 PM
  2. Wanted: Blown Amp For Custom Project!
    By nFiniteTuning in forum Classified Archive
    Last Post: 11-22-2004, 12:53 PM
  3. Is it blown?
    By EBFoxbat in forum Car Audio
    Last Post: 10-11-2004, 09:12 PM
  4. Blown Engine Repair
    By Ashlawn Kemling in forum Off Topic
    Last Post: 09-28-2003, 09:10 PM
  5. need some serious help: blown headgasket
    By bgoodman in forum Off Topic
    Last Post: 12-08-2002, 06:35 PM
