Results 1 to 9 of 9
Thread: HELP having some problems!
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    perhaps an opus 150 problem? ok im having few problems..im using a mini itx via p4 board with a p4 1.7 mobile chip that runs at 1.2g and consumes 30 watts.. i have 4 usb devices..gps. touchscreen. external 2.5 hdd. and slim dvd. also running a 3.5 200gb hdd. the first day it worked fine! now when i start my car it starts windows..if i shut the car off fill up gas and turn the car back on it wont start back up? i have to keep trying again and again!? after 5 minutes of trying it will work again. also i installed media engines new beta...tonight i noticed alot of skipping in songs and my iguidance was losing gps signal alot..i never had this problem with my old hp epc.. now i read up and searched and i found out the opus needs its own line str8 to the battery..8 guage is good..i saw this tonight so i didnt get a chance to do it yet..now do you guys think my problem is my wiring not thick enough? or do you think im not running enough power to the computer from the 150 watt opus? i know im not overkilling my usb devices..do you think my media engine problem can be related to a power issue?
    Jan 2005
    Chicago, IL
    bump
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    what size is the wire your running to opus at this point? because i have a machine with a full size drive and a P4 2.3 and a CDRW and it runs great.
    肚子笑痛了
    S60 Install
    Jan 2005
    Chicago, IL
    im not sure..its a little thinner than the original opus wire...im gonna buy some 8 guage wire today and try it..thanks!
    tja
    tja is offline
    Aug 2005
    sydney, australia
    do you have ACPI installed? i had all sorts of shutdown/startup problems until i reinstalled windows with ACPI (advanced cconfiguration and power interface or something?)
    it would shut down, wouldnt start back up again until i totally removed power to the opus...
    you can tell if u have ACPI installed if u right click my computer >> properties >> hardware >> device manager >> computer >> you should have ACPI listed in there under the computer tab..
    you need ACPI to be able to hibernate properly (using the power button/automatic opus switch on/off)
    i hope that made snese i wrote this in a hurry at work!!!
    only problem is that to install ACPI u need an ACPI compatible motherboard, and you need to do a clean install of windows
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    You know, I think he may have fixed it by now....
    Jan 2005
    Chicago, IL
    hehe lol
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by pip
    Hey Pip, good to see you arround... Yeah, I think it has been fixed for some time
    TruckinMP3
    Read the FAQ!
    tja
    tja is offline
    Aug 2005
    sydney, australia
    holy crap how did i manage that?
    2005 Nissan Xtrail
    worklog
  1. opus problems
    By studmonk3y in forum Power Supplies
    Last Post: 03-29-2005, 04:09 PM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 03:37 PM
  3. Replies: 3
    Last Post: 02-19-2005, 01:35 AM
  4. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
  5. Shutdown Problems - Troubleshooting Guide
    By brettwmd in forum Power Supplies
    Last Post: 05-28-2004, 11:46 AM
