Results 1 to 5 of 5
Thread: Need help identifying a relay
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    I am looking for a tiny relay that does one simple thing: it opens or closes a single circuit when I send it a momentary pulse. In my case (in car), when I send it a momentary 12v, it closes the circuit and stays closed even when the 12v is gone. Then, when I pulse it again with 12V, it opens the circuit and stays open. What is this called??
    Apr 2003
    HOT Arizona
    Nov 2004
    Netherlands
    It's called hier a Bi-stabiel or polair relais.. I'm only not sure if their name is the same in English...
    It's a relay which gets a pulse and then just switches, with another pulse it will release. Without power it will remain in the same setting as after the last pulse.
    Found it, its called an unipolar relay. Conrad has them for example. ( www.conrad.com ), art.no PULSE RELAY 12 V DC Part no.: 505463 - I5
    Bi-stable, pure mechanical storage of contact switching positions Unipolar, same pulse (power and current direction!) for both switch positions
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    They are called latching relays. Man, I was sitting here for like 10 minutes trying to think of that. One pulse, and the hold the contacts closed. Another pulse, usually to another set of coils, or to the same set but in reverse, and they open again.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Apr 2003
    HOT Arizona
    Quote Originally Posted by DJSmiley
    ROCKONN!!!!!!!!
    Thanks!
  1. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 07:55 PM
  2. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:39 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  4. Queston conerning stinger 200 amp relay
    By vash in forum General Hardware Discussion
    Last Post: 05-25-2004, 10:15 AM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 04:50 AM
