Results 1 to 7 of 7
Thread: Identify this connector...
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Help me identify this connector...
    I took apart my Mazda steering wheel and the clockspring has this kind of connector. Any ideas who makes them so I can buy some pins and sockets to match? I can't find any writing anywhere...
    Jan 2003
    Ruston, LA
    it's a lesbian connector !
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Apr 2003
    HOT Arizona
    Quote Originally Posted by frodobaggins
    Hmm, the sockets are female but the housing is male so I think it's straight...
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by ddogg_777
    Doesn't look that far off a floppy drive power connector does it ?
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    more likely Asexual as it can reproduce by itself.
    there is an idea, jsut wrap it up warm, give it some food and in the morning you will have another one. No need to go down the shop!
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    But don't feed it after midnight. Or get it wet. Otherwise you'll get a gremlin.
    But seriously, check with your local Mazda service department for something like a Connector or Wiring Repair Kit. Its not a "standard" connector. But if you can use the white plastic housing, then Digikey may have the pins to go into that housing if they're either .100" or .156" (it's a little hard to tell scale from the picture).
    .100" Digikey WM2612-ND
    .156" Digikey WM2300-ND (Not square like the picture but may still work)
    Hope this helps.
    Apr 2003
    HOT Arizona
    Every little bit helps, thanks!
  1. 8" Lilliput connector question
    By 99C5Vert in forum LCD/Display
    Last Post: 11-18-2004, 11:00 PM
  2. Lilliput connector problem? is there a fix?
    By tmar89 in forum LCD/Display
    Last Post: 09-19-2004, 05:02 AM
  3. Slimline Slot-load DVD from New-egg (identify connector)
    By hevnsnt in forum General Hardware Discussion
    Last Post: 08-16-2004, 07:53 PM
  4. need connector for CD drive cable
    By turbochris in forum General Hardware Discussion
    Last Post: 07-12-2004, 02:55 PM
  5. Replies: 2
    Last Post: 10-07-2001, 12:43 PM
