Results 1 to 10 of 16
Thread: Dual Display Problem on M-II w/PowerDVD
    Mar 2005
    On my M-II I'm using the VGA for the front dash display and also have a rear overhead connected S-Video. I'd like the two displays to just be identical. I've set it up in XP to do that and it works perfectly except when using PowerDVD. When I play a DVD, the screens look identical except that on the VGA display, the window where the video is supposed to be is just black. The S-Video is fine.
    I'd like to get the same display on both, but if I can't, I'd at least like to be able to choose front or rear. I've played with the setting in PowerDVD for Primary or Secondary but it doesn't seem to make a difference. I've tried it w/Zoom Player and it does the same thing (although in the DVD Configuration it's using PowerDVDs video stuff).
    For BIOS settings, I've got the Display set for CRT+TV and the TV Layout setting set for S-Video.
    What else needs to be done in order to be able to get the DVD video to the front VGA while keeping it in the rear S-Video or having the rear be the one with the black video window?
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    LOL, this is exactly what I am trying to achieve in my setup. I dont wont them to be identical. Now if you could tell us more about your setup/hardware which VideoCard u r using, bios versions etc. we could be of more assistance....
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Its evil copy protection.
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    Actually it sounds like you are having a problem with Direct Draw. It seems that some video card drivers don't support using Direct draw on two or more monitors at the same time. Make sure that your DirectX and Video card drivers are up to date and look for any settings in the disply properties that might indicate a way to enable using direct draw on both monitors.
    Newbie SPiTFirE's Avatar
    Mar 2005
    It sounds to me like you are having overlay problems. I know on one of my pc's with an ATI graphics card one screen would stay black until I changed the overlay options. After that it worked like a charm!
    I'm not sure what type of overlay control you have with the onboard video, but check in the advanced display settings and see if you can change it around.
    My 1967 Mustang
    CarPC in progress
    Mar 2005
    Thanks so far to everyone who's contributed.
    SPiTFirE definitely got the switching thing right. My M-II uses the VIA/S3G CLE266 graphics "card" (I believe it's embedded on the motherboard) and my BIOS version is 98.C7.00.16 (7/25/03). There's an Overlay tab in the Advanced Properties of the screen Settings and there's a button there that says "Switch". Clicking that does shift the DVD video from front to rear. You MUST have a DVD playing or the button isn't available. That's how I missed it. Either/or problem now solved. Thanks SPiTFirE.
    Next step is to try to get it on both without using anymore hardware. HostileJava, I'm using DirectX 9.0b. Since the S3Graphics settings stuff has that "Switch" button, it's hard to imagine it's geared up to work on both at the same time. Any other place I should be looking or anything else to try? Everything else about the two screens is identical, which is how I want it, it's just the overlay that seems to be either/or.
    If anyone else has suggestions, by all means....
    Mar 2005
    Northampton, PA
    Unfortionately it sounds like your videocard driver only supports the Direct Draw Video overlay on one monitor at a time. Maybe you can find a hacked version of the driver? Usually its because the card can't handle it though.
    Aug 2003
    Greece
    Why dont you try another DVD player sofftware....U never know!
    Dec 2004
    It could just be that in your screen properties you need to go to settings and then advanced, look at the displays and make sure both are selected. If only one is the video shows on one not the other. Everything shows on both displays but video then this is probly the problem.
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by DrDeriv
    I have a M10K motherboard and I have exactly the same problem with my rear RCA screen. It seems that the M Series embedded graphics/drivers can only handle the one video overlay. I don't use DVD, I play AVI, DIVX movies direct from the hard drive, but the same problem still exists.
    A VGA splitter might work with two VGA screens, but like me you have VGA and RCA.
    If someone has cracked this problem, let us know how.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  1. Display problem
    By djtino in forum ME Archive
    Last Post: 07-16-2003, 01:38 PM
  2. Display problem
    By knix in forum ME Archive
    Last Post: 07-14-2003, 01:05 AM
  3. Display problem in ME
    By cjones in forum ME Archive
    Last Post: 03-11-2003, 11:01 AM
  4. dual display
    By maximilian in forum LCD/Display
    Last Post: 09-20-2002, 01:07 AM
  5. problem with monitor/LCD display
    By seven10split in forum General Hardware Discussion
    Last Post: 08-12-2000, 07:46 PM
