Results 1 to 10 of 17
Thread: EIDE Cable Connectors
    Constant Bitrate Lando's Avatar
    Apr 2002
    Does anyone no where I can find one of these ( or even now what I'm talking about. It's like a plastic piece with a male eide pin set on either side used for connecting to cables with female ends
    Aut cum scuto, aut in scuto
    Tainted Love Cris's Avatar
    Romania
    Must say I haven't seen one. What do you need it for?
    Elsewhere
    Quote Originally Posted by Lando
    Something like this:
    http://shop.store.yahoo.com/cableson...40pinidem.html
    I think that's as close as you're going to get. I've seen what you're describing in 44-pin for laptop drives, but it's a smaller pin arrangement.
    I'm reasonably certain you can find what you're looking for at an electronics shop.
    How about the Wiki?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Carfully diassemble an existing cable? Might be worth it if you have one that is shorter than you need (or longer I guess)
    TruckinMP3
    Read the FAQ!
    Apr 2002
    this
    This is what I was looking for but this one is 44 pin like for a laptop
    http://www.cablesonline.com/44pinmalidc2.html
    Elsewhere
    And that will likely be smaler than what you need for EIDE. The pins are closer together than a standard IDE connector, so it wouldn't work.
    Yoiu might try an electronics shop and see if they have what you need. You may end up getting something 50-pin and hacking off 5 rows or something.
    How about the Wiki?
    Apr 2002
    What about an EIDE cable 6 to 10 inches long with female on one end and male on the other? Think I can find somthing like that?
    Jun 2002
    Colorado
    Try looking...
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    if it's not a boot drive I'd use firewire or USB2 .. fire is 6 wires.. USB 1.1 was 4 .. not sure what USB2 is..
    then get a extenal driv eenclose and use the hardware from that.. the great thing there is you can use external 12v power.. I use that for my cd/dvd drive..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Apr 2002
    Blow me truckin, I was asking for help because I already looked and I couldnt find one. I wanted to know if any one knew where I could get one
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. EIDE to Firewire cable ?
    By Lando in forum General Hardware Discussion
    Last Post: 03-13-2005, 12:56 PM
  3. Replies: 8
    Last Post: 04-30-2003, 11:49 PM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. laptop eide connectors
    By mp3z24 in forum Classified Archive
    Last Post: 06-10-2002, 04:29 PM
