zPilott, that's great that you're getting back into this interface. I remember reading about your first serial version. With you and jimbonzzz doing V1 software, it can only help to inspire more hardware development. I'll read up on the USBMOD3 and see if I can contribute anything.
EDIT: Also, according to Jim's schematics, a resistance value of at least 3.6k is necessary to turn off the V1's display and send the display signal to the concealed display if you don't have one already hooked up. If you do, you should be able to use an RJ11 splitter and forego the need for the resistor loop between +12V and the data line (looks like you've got a 2.2k between +5V and data).
This USB interface looks promising (and simple to boot!).
EDIT2: Is your diode facing that direction intentionally? If I'm reading it correctly, that's the RXD line, and if you have the cathode on that side, wouldn't it be blocking the signal?
LinkBack URL
About LinkBacks
. The first one I made I was getting some data back from, but it didn't make sense. It was now sending a bit of data then quitting ( the serial connection with the max232 would continuously transmit). It also wasn;t extinguishing the V1 display. I thought it was a problem with my interface, but I later checked out my remote display, and it didn't work either. I tried hooking it up with different cables and the remote worked, but now I can't find the original adapter that I made (it got lost in my 2000 mile move, I guess). I tried making another one, and I am getting NO output from the V1 in my application.
