I would leave the computer out of it unless you must. You could always add a switch somewhere that turned your feature on/off.
Now to the actual question: I don't see why you couldn't do it. If you tap the line that lights the LED, you could have it also switch a relay; that relay will then close the same loop that your button does. This is only contigent on the LED line being able to carry enough current for the relay, which I would be shocked if it couldn't. You should also find out how much current is passing though the button, and get an approprietely rated relay.
if you're comfortably with the electronics, the hardest part is probably going to be taking apart your dash to tap the LED and button lines.
edit: Parting thought - The voltage in the LED line might not be enough for the relay. In that case, you'll need to use a transistor and a 12V line (this would also be the solution if the LED line can't carry the current).
LinkBack URL
About LinkBacks
There are a lot of good references and tutorials on line. Unfortunately I can't point to any off the top of my head, but I'm sure Google can find them for you. Then I'd say it's just a matter of trying out stuff to get a feel for it. Everything I described is pretty basic stuff, and if it didn't involve your car (which I'm sure you don't want to ***** up on
), I'd say it'd be a great first project.
