Yes you can.![]()
I currently have my harddrive a few inches away from the mobo. But my IDE cable is pretty long. Could I cut the cable here,
and plug in the supposed "slave" part into my motherboard, and the harddrive to the "master" part?
90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
My Install
Yes you can.![]()
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
the logical solution would be to try it... then cut if it works. cutting the cable isn't going to affect anything, so as long as it works with the other two connectors before cutting, it'll work after. (just make sure you cut it CLEANLY... I cut an IDE cable a while back with crappy cutters and the wires frayed and shorted out, and it refused to work until I re-cut it cleanly)
Yes it works, I did it.
Also it is depend on how you have your drive detect by the mobo. If I put on cable select, doesn't work. Manual select, yes and must set jumper accordingly.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Use a big sharp machette to get a clean cut!
just thought, make sure you use the bit on the right not the left!
seriosuly, if you find you are getting frayed edges cut at a slight angle and stagger the ends. jsut very slightly though
cool, thanx~! I'll see if I have a machette around here...
My Install
Just use a sharp pair of scissors, it works fine.
lol![]()
My Install
Would it be smart to seal the end somehow? Put a few strips of electrical tape on the exposed end?
NO!!!! use a machette -it's more fun! and you can be like Nick Dundee!
