Results 1 to 6 of 6
Thread: Optimize
    Low Bitrate Mcnovy's Avatar
    Feb 2005
    Denmark
    Question Optimize
    Hi..
    well, i got my pieces for at CarPC..
    My Configuration is:
    Via Epia MII 12000
    512 Mb Ram
    PCmcia asus wi-fi
    Usb Bluetooth
    Well, my Question is:
    i've been thinking of have a double screen, i got one xenarc toucscreen, im about to mount in the double din.
    and thinkin of buying a Roof screen, (not sure if touchscreen or not)
    is it possible of using 2 screens with the epia's onboard GFX (one vga, and one s-vhs (the rca is used for SP/Dif)
    would it help the perfomance of the epia also, when using Map Monkey..? (its a bit laggy when scrooling the screen..!)
    and help the perfomance when both using navi, and watching a Music Video ( DivX . etc) etc. if i bought a PCI GFX (will it "help" the CPU from the rather slow epia...? ) (and how is the power consumption from a GFX Card)
    also, i've been thinkin of a usb sound card, many users say that it a much better sound Quality, can someone confirm , or disconfirm this..?
    and again, will it help the CPU from the Epia (so the CPU can concentrate on running the machine fast, and smooth (centrafuse anyone..? )
    and wich USB Sound card do you recommend..?
    other tips on optimizing the epia board, boot times, working in windows, and applications, and other suggestions are Welcome..!
    hope i've made myself Clear..
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have an Epia M10000 and can run music, GPS and voice recognition without problems, so your M12000 shouldn't have any trouble with it.
    You can run two screens if one is VGA and the other is S-VGA. There may be an issue about which one would display video if you play that. If you don't mind both screen displaying the same image, you could get a VGA splitter and put a VGA screen in your roof.
    There's a recent thread about this here: Help with Epia M10K RCA Video
    Want to:
    Feb 2005
    Denmark
    thx for the answer, but does anyone know if the sound quality is better with a usb thingy
    CarPC Specs.
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by Mcnovy
    I use the SoundBlaster MP3+ USB sound "thingy", and it cuts down on ground noise quite a bit. Generally, an external soundcard is good to have.
    Newbie trimpy's Avatar
    Mar 2005
    Grand Rapids, MI
    Quote Originally Posted by Bugbyte
    If you use the HD15 VGA connector using the Svideo/RCA vid out on the motherboard will be utilized by extending your desktop to it in the display properties. You can only display video on the primary monitor (selectable with a checkbox) and on the secondary screen you will just see the black overlay box for the vid. Everything else that doesn't use a video overlay will work fine on either screen.
    2003 VW Jetta Wagon 1.9L TDI 5 speed
    <|||-------> 35% ish
    CarNetix P1280 80w
    EPIA TC10000 Mobo, 512MB SODIMM DDR, 160GB HD, Orinoco 802.11b, Hollux GPS (USB), 12dBi Omni Antenna
    Waiting on:
    DWW-700M 7" 1-DIN Display :-D (2 weeks maybe!)
    Apr 2005
    Silicon Valley
    Quote Originally Posted by XxAndyxX
    cuts down on ground noise and RF interference from the mobo. on-board sound chips are notoriously crappy for quality sound. PCI/IDE cards are only slightly better. Luckily, I'm halfway deaf anyways so i could give a rat's *** but if you have a nice sound system in your car you'll notice. External (USB or breakout box) sound cards, if of good quality with a dedicated DSP etc., are much nicer.
    __
    Amoebacowboy
    "Do Not Taunt Happy-Fun Ball"
  1. Optimize Load time of CF?
    By HostileJava in forum Centrafuse
    Last Post: 03-16-2005, 08:40 AM
  2. nLite image - Bootvis won't optimize
    By kpjuk in forum WinNT Based
    Last Post: 02-01-2005, 08:45 PM
  3. Help: need to optimize M10000 for DIVX
    By fasternfaster in forum General Hardware Discussion
    Last Post: 11-17-2004, 07:59 PM
  4. Optimize Your Windows
    By 100mph in forum Software & Software Development
    Last Post: 06-30-2004, 01:26 PM
  5. Wireless AP settings: Optimize for range
    By bombboyer in forum General Hardware Discussion
    Last Post: 10-29-2002, 12:51 AM
